{"name":"Ruuvi Cloud Shop","description":"Measure Your World","url":"https:\/\/cloud.ruuvi.com","home":"https:\/\/cloud.ruuvi.com\/fi\/","gmt_offset":3,"timezone_string":"Europe\/Helsinki","page_for_posts":0,"page_on_front":52225,"show_on_front":"page","namespaces":["oembed\/1.0","wpml\/v1","redirection\/v1","wc\/v3","wc\/v1","wc\/pos\/v1\/catalog","yoast\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","jetpack\/v4","wc-admin","wc-analytics","wc\/store","wc\/store\/v1","wc\/private","wp-2fa-methods\/v1","wp-2fa-passkeys\/v1","yaysmtp\/v1","wc\/v2","adtribes\/v1","ruuvi\/v1","regenerate-thumbnails\/v1","wc-admin-email","wc-telemetry","wccom-site\/v3","otgs\/installer\/v1","wp-abilities\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/cloud.ruuvi.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Sen resurssin URL jonka oEmbed-tiedot noudetaan.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Sen resurssin URL jonka oEmbed-tiedot noudetaan.","type":"string","format":"uri","required":true},"format":{"description":"K\u00e4ytett\u00e4v\u00e4 oEmbed-muoto.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Upotettavan kehyksen maksimileveys pikselein\u00e4.","type":"integer","default":600,"required":false},"maxheight":{"description":"Upotettavan kehyksen maksimikorkeus pikselein\u00e4.","type":"integer","required":false},"discover":{"description":"Tehd\u00e4\u00e4nk\u00f6 oEmbed-tiedustelukutsu ennalta hyv\u00e4ksym\u00e4tt\u00f6mien palveluntarjoajien palveluihin.","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/redirect\/post":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"text":{"description":"Text to match","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/redirect\/post"}]}},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"global":{"description":"Apply bulk action globally, as per filters","type":"boolean","required":false},"items":{"description":"Array of IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Name","type":"string","required":false},"value":{"description":"Value","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin\/test"}]}},"\/redirection\/v1\/plugin\/data":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"upgrade":{"description":"Upgrade parameter","type":"string","enum":["stop","skip","retry"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin\/data"}]}},"\/redirection\/v1\/plugin\/finish":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin\/finish"}]}},"\/redirection\/v1\/plugin\/fix":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"reason":{"description":"Reason for fix","type":"string","required":true},"current":{"description":"Current version","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/plugin\/fix"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3"}]}},"\/wc\/v3\/marketplace\/featured":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/featured"}]}},"\/wc\/v1":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1"}]}},"\/wc\/v1\/marketplace\/product-preview":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/marketplace\/product-preview"}]}},"\/wc\/v3\/marketplace\/refresh":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/refresh"}]}},"\/wc\/v3\/marketplace\/subscriptions":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions"}]}},"\/wc\/v3\/marketplace\/subscriptions\/connect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions\/connect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate-plugin":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate-plugin"}]}},"\/wc\/v3\/marketplace\/subscriptions\/disconnect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions\/disconnect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate"}]}},"\/wc\/v3\/marketplace\/subscriptions\/install-url":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/subscriptions\/install-url"}]}},"\/wc\/v3\/marketplace\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/marketplace\/create-order"}]}},"\/wc\/pos\/v1\/catalog":{"namespace":"wc\/pos\/v1\/catalog","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/pos\/v1\/catalog","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/pos\/v1\/catalog"}]}},"\/wc\/pos\/v1\/catalog\/create":{"namespace":"wc\/pos\/v1\/catalog","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"force":{"type":"boolean","default":false,"description":"Force regeneration of the feed. NOOP if generation is in progress.","required":false},"_product_fields":{"type":"string","description":"Comma-separated list of fields to include for non-variable products.","required":false},"_variation_fields":{"type":"string","description":"Comma-separated list of fields to include for variations.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/pos\/v1\/catalog\/create"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefix to add before the stats identifiers.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/troubleshooting\/posthog":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/troubleshooting\/posthog"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/website-contexts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/website-contexts"}]}},"\/wpml\/v1\/has-posts-using-native-editor":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/has-posts-using-native-editor"}]}},"\/wpml\/v1\/get-credits-to-translate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/get-credits-to-translate"}]}},"\/wpml\/v1\/get-credits-per-word":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/get-credits-per-word"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/minimum-requirements":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/minimum-requirements"}]}},"\/wpml\/v1\/rest\/status":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/rest\/status"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/wpml\/v1\/wpml\/posthog\/capture-event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/wpml\/posthog\/capture-event"}]}},"\/wpml\/v1\/wpml-proxy\/status":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/wpml-proxy\/status"}]}},"\/wpml\/v1\/wpml-content-stats":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/wpml-content-stats"}]}},"\/wpml\/v1\/wpml-ph-make-external-request":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wpml\/v1\/wpml-ph-make-external-request"}]}},"\/wc\/v3\/wc_stripe\/connection_tokens":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/connection_tokens"}]}},"\/wc\/v3\/wc_stripe\/terminal\/locations":{"namespace":"wc\/v3","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"display_name":{"type":"string","required":true},"address":{"type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"ending_before":{"type":"string","required":false},"limit":{"type":"integer","required":false},"starting_after":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/terminal\/locations"}]}},"\/wc\/v3\/wc_stripe\/terminal\/locations\/store":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/terminal\/locations\/store"}]}},"\/wc\/v3\/wc_stripe\/terminal\/locations\/(?P<location_id>\\w+)":{"namespace":"wc\/v3","methods":["DELETE","GET","POST"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"display_name":{"type":"string","required":false},"address":{"type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/wc_stripe\/orders\/(?P<order_id>\\d+)\/create_customer":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/wc_stripe\/orders\/(?P<order_id>\\w+)\/capture_terminal_payment":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"payment_intent_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/wc_stripe\/tokens\/(?P<token_id>[a-z]{3}_[a-zA-Z0-9]{24})":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/wc_stripe\/account":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account"}]}},"\/wc\/v3\/wc_stripe\/account\/summary":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account\/summary"}]}},"\/wc\/v3\/wc_stripe\/account\/webhook-status-message":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account\/webhook-status-message"}]}},"\/wc\/v3\/wc_stripe\/account\/refresh":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account\/refresh"}]}},"\/wc\/v3\/wc_stripe\/upe_flag_toggle":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"is_upe_enabled":{"description":"Determines if the UPE feature flag is enabled.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/upe_flag_toggle"}]}},"\/wc\/v3\/wc_stripe\/settings":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"is_stripe_enabled":{"description":"If Stripe should be enabled.","type":"boolean","required":false},"is_test_mode_enabled":{"description":"Stripe test mode setting.","type":"boolean","required":false},"enabled_payment_method_ids":{"description":"Payment method IDs that should be enabled. Other methods will be disabled.","type":"array","items":{"type":"string","enum":["alipay","bancontact","blik","card","eps","giropay","ideal","klarna","link","multibanco","p24","sepa_debit","sofort","us_bank_account","wechat_pay"]},"required":false},"is_oc_enabled":{"description":"If Optimized Checkout should be enabled.","type":"boolean","required":false},"is_ap_enabled":{"description":"If Adaptive Pricing should be enabled.","type":"boolean","required":false},"oc_layout":{"description":"The Optimized Checkout layout (accordion or tabs).","type":"string","enum":["accordion","tabs"],"required":false},"amazon_pay_button_size":{"description":"Express checkout button sizes.","type":"string","enum":["small","default","large"],"required":false},"amazon_pay_button_locations":{"description":"Express checkout locations that should be enabled.","type":"array","items":{"type":"string","enum":["product","cart","checkout"]},"required":false},"is_payment_request_enabled":{"description":"If Stripe express checkouts should be enabled.","type":"boolean","required":false},"payment_request_button_type":{"description":"Express checkout button types.","type":"string","enum":["default","buy","donate","book"],"required":false},"payment_request_button_theme":{"description":"Express checkout button themes.","type":"string","enum":["dark","light","light-outline"],"required":false},"payment_request_button_size":{"description":"Express checkout button sizes.","type":"string","enum":["small","default","large"],"required":false},"payment_request_button_locations":{"description":"Express checkout locations that should be enabled.","type":"array","items":{"type":"string","enum":["product","cart","checkout"]},"required":false},"is_manual_capture_enabled":{"description":"If manual capture of charges should be enabled.","type":"boolean","required":false},"is_saved_cards_enabled":{"description":"If \"Saved cards\" should be enabled.","type":"boolean","required":false},"is_sepa_tokens_for_ideal":{"description":"If \"SEPA tokens for iDEAL\" should be enabled.","type":"boolean","required":false},"is_sepa_tokens_for_bancontact_enabled":{"description":"If \"SEPA tokens for Bancontact\" should be enabled.","type":"boolean","required":false},"is_separate_card_form_enabled":{"description":"If credit card number field, expiry date field, and CVC field should be separate.","type":"boolean","required":false},"is_short_statement_descriptor_enabled":{"description":"When enabled, we'll include the order number for card and express checkout transactions.","type":"boolean","required":false},"is_debug_log_enabled":{"description":"When enabled, payment error logs will be saved to WooCommerce > Status > Logs.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/settings"}]}},"\/wc\/v3\/wc_stripe\/settings\/payment_method_order":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"ordered_payment_method_ids":{"description":"The order for the payment method IDs to be saved.","type":"array","items":{"type":"string","enum":["alipay","bancontact","blik","card","eps","giropay","ideal","klarna","link","multibanco","p24","sepa_debit","sofort","us_bank_account","wechat_pay"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/settings\/payment_method_order"}]}},"\/wc\/v3\/wc_stripe\/settings\/notice":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/settings\/notice"}]}},"\/wc\/v3\/wc_stripe\/account_keys":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"publishable_key":{"description":"Your Stripe API Publishable key, obtained from your Stripe dashboard.","type":"string","required":false},"secret_key":{"description":"Your Stripe API Secret, obtained from your Stripe dashboard.","type":"string","required":false},"webhook_secret":{"description":"Your Stripe webhook endpoint URL, obtained from your Stripe dashboard.","type":"string","required":false},"test_publishable_key":{"description":"Your Stripe testing API Publishable key, obtained from your Stripe dashboard.","type":"string","required":false},"test_secret_key":{"description":"Your Stripe testing API Secret, obtained from your Stripe dashboard.","type":"string","required":false},"test_webhook_secret":{"description":"Your Stripe testing webhook endpoint URL, obtained from your Stripe dashboard.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account_keys"}]}},"\/wc\/v3\/wc_stripe\/account_keys\/test":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"publishable_key":{"description":"Your Stripe API Publishable key, obtained from your Stripe dashboard.","type":"string","required":false},"secret_key":{"description":"Your Stripe API Secret, obtained from your Stripe dashboard.","type":"string","required":false},"test_publishable_key":{"description":"Your Stripe testing API Publishable key, obtained from your Stripe dashboard.","type":"string","required":false},"test_secret_key":{"description":"Your Stripe testing API Secret, obtained from your Stripe dashboard.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account_keys\/test"}]}},"\/wc\/v3\/wc_stripe\/account_keys\/configure_webhooks":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"live_mode":{"description":"Whether the account is in live mode.","type":"boolean","required":false},"secret_key":{"description":"Your Stripe API Secret, obtained from your Stripe dashboard.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/account_keys\/configure_webhooks"}]}},"\/wc\/v3\/wc_stripe\/oc_setting_toggle":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"is_oc_enabled":{"description":"Determines if the OC setting is enabled.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/wc_stripe\/oc_setting_toggle"}]}},"\/wc-admin":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin"}]}},"\/wc-admin\/notice\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/notice\/dismiss"}]}},"\/wc-admin\/features":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/features"}]}},"\/wc-admin\/experiments\/assignment":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/experiments\/assignment"}]}},"\/wc-admin\/marketing\/recommended":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"category":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/recommended"}]}},"\/wc-admin\/marketing\/knowledge-base":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/knowledge-base"}]}},"\/wc-admin\/marketing\/misc-recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/misc-recommendations"}]}},"\/wc-admin\/marketing\/overview\/activate-plugin":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/overview\/activate-plugin"}]}},"\/wc-admin\/marketing\/overview\/installed-plugins":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/overview\/installed-plugins"}]}},"\/wc-admin\/marketing\/recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","enum":["channels","extensions"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/recommendations"}]}},"\/wc-admin\/marketing\/channels":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/channels"}]}},"\/wc-admin\/marketing\/campaigns":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/campaigns"}]}},"\/wc-admin\/marketing\/campaign-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/marketing\/campaign-types"}]}},"\/wc-admin\/options":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/options"}]}},"\/wc-admin\/legacy-settings":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"schema":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/legacy-settings"}]}},"\/wc-admin\/payment-gateway-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Return the default payment suggestions when woocommerce_show_marketplace_suggestions and woocommerce_setting_payments_recommendations_hidden options are set to no","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/payment-gateway-suggestions"}]}},"\/wc-admin\/payment-gateway-suggestions\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/payment-gateway-suggestions\/dismiss"}]}},"\/wc-admin\/themes":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"pluginzip":{"description":"Palvelimelle siirrett\u00e4v\u00e4n teeman .zip tiedosto.","type":"file","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/themes"}]}},"\/wc-admin\/plugins\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/install"}]}},"\/wc-admin\/plugins\/install\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/install\/status"}]}},"\/wc-admin\/plugins\/install\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/plugins\/active":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/active"}]}},"\/wc-admin\/plugins\/installed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/installed"}]}},"\/wc-admin\/plugins\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/activate"}]}},"\/wc-admin\/plugins\/activate\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/activate\/status"}]}},"\/wc-admin\/plugins\/activate\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/plugins\/connect-jetpack":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/connect-jetpack"}]}},"\/wc-admin\/plugins\/request-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/request-wccom-connect"}]}},"\/wc-admin\/plugins\/finish-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/finish-wccom-connect"}]}},"\/wc-admin\/plugins\/connect-wcpay":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/connect-wcpay"}]}},"\/wc-admin\/plugins\/connect-square":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/plugins\/connect-square"}]}},"\/wc-admin\/onboarding\/free-extensions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/free-extensions"}]}},"\/wc-admin\/onboarding\/product-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/product-types"}]}},"\/wc-admin\/onboarding\/profile":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"completed":{"type":"boolean","description":"Tehtiink\u00f6 profiili loppuun saakka vai ei.","required":false},"skipped":{"type":"boolean","description":"Profiilin ohittaminen tai ohittamatta j\u00e4tt\u00e4minen.","required":false},"industry":{"type":"array","description":"Toimiala.","items":{"type":"string"},"required":false},"business_extensions":{"type":"array","description":"Lis\u00e4\u00e4 asennettavia laajennuksia liiketoimintaa varten.","items":{"type":"string"},"required":false},"is_agree_marketing":{"type":"boolean","description":"Whether or not this store agreed to receiving marketing contents from WooCommerce.com.","required":false},"store_email":{"type":"string","description":"Kaupan s\u00e4hk\u00f6postiosoite.","required":false},"is_store_country_set":{"type":"boolean","description":"Whether or not this store country is set via onboarding profiler.","required":false},"is_plugins_page_skipped":{"type":"boolean","description":"Ohitettiinko lis\u00e4osavaihe ydinprofiloijassa vai ei.","required":false},"business_choice":{"type":"string","description":"Business choice.","required":false},"selling_online_answer":{"type":"string","description":"Selling online answer.","required":false},"selling_platforms":{"type":["array","null"],"description":"Selling platforms.","items":{"type":["string","null"]},"required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/profile"}]}},"\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill"}]}},"\/wc-admin\/onboarding\/profile\/progress":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/profile\/progress"}]}},"\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","description":"The Core Profiler step to mark as complete.","enum":["intro-opt-in","skip-guided-setup","user-profile","business-info","plugins","intro-builder","skip-guided-setup"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete"}]}},"\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"description":"Maatunnus.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units"}]}},"\/wc-admin\/onboarding\/tasks\/import_sample_products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/tasks\/import_sample_products"}]}},"\/wc-admin\/onboarding\/tasks\/create_homepage":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/tasks\/create_homepage"}]}},"\/wc-admin\/onboarding\/tasks\/create_product_from_template":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template_name":{"type":"string","description":"Tuotepohjan nimi.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/tasks\/create_product_from_template"}]}},"\/wc-admin\/onboarding\/tasks":{"namespace":"wc-admin","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"ids":{"description":"Valinnainen muuttuja, jolla voi hakea valitun teht\u00e4v\u00e4listan id:ll\u00e4.","type":"array","items":{"enum":[],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"ids":{"description":"Valinnainen muuttuja, jolla voi hakea valitun teht\u00e4v\u00e4listan id:ll\u00e4.","type":"array","items":{"enum":[],"type":"string"},"required":false},"extended_tasks":{"description":"Luettelo asiakaspuolen suodattimen laajennetuista vanhentuneista teht\u00e4vist\u00e4.","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/tasks"}]}},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/unhide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_-]+)\/snooze":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"duration":{"description":"Time period to snooze the task.","type":"string","required":false},"task_list_id":{"description":"Optional parameter to query specific task list.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/action":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_snooze":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/themes\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/themes\/install"}]}},"\/wc-admin\/onboarding\/themes\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/themes\/activate"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate-async":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"description":"A list of plugins to install","type":"array","items":"string","required":true},"source":{"description":"The source of the request","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate-async"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate"}]}},"\/wc-admin\/onboarding\/plugins\/scheduled-installs\/(?P<job_id>\\w+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"The URL to redirect to after authorization","type":"string","required":true},"from":{"description":"from value for the jetpack authorization page","type":"string","default":"woocommerce-onboarding","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url"}]}},"\/wc-admin\/onboarding\/products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/onboarding\/products"}]}},"\/wc-admin\/mobile-app\/send-magic-link":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/mobile-app\/send-magic-link"}]}},"\/wc-admin\/mobile-app":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/mobile-app"}]}},"\/wc-admin\/shipping-partner-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Return the default shipping partner suggestions when woocommerce_show_marketplace_suggestions option is set to no","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/shipping-partner-suggestions"}]}},"\/wc-analytics":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-analytics","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics"}]}},"\/wc-analytics\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Rajoita vastaus kohteisiin joissa asiakas kentt\u00e4 sis\u00e4lt\u00e4\u00e4 etsityn sanan. Etsii kent\u00e4st\u00e4 joka annettu kohdassa `searchby` (etsi t\u00e4\u00e4lt\u00e4).","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"name_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"username_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"username_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"email_includes":{"description":"Rajoita vastaus kohteisiin joissa sis\u00e4llytet\u00e4\u00e4n s\u00e4hk\u00f6posteja.","type":"string","required":false},"email_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan s\u00e4hk\u00f6posteja.","type":"string","required":false},"country_includes":{"description":"Rajoita vastaus kohteisiin joissa tietyt maat.","type":"string","required":false},"country_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tietyt maat.","type":"string","required":false},"last_active_before":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_max":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_between":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on ennen tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on joko my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"users":{"description":"Limit result to items with specified user ids.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Suodata tulokset, joissa mik\u00e4 tahansa l\u00e4hetetyist\u00e4 kentist\u00e4 on tyhj\u00e4","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"include":{"description":"Rajoita tulokset kohteisiin joissa tietty asiakastunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/customers"}]}},"\/wc-analytics\/customers\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Rajoita vastaus kohteisiin joissa asiakas kentt\u00e4 sis\u00e4lt\u00e4\u00e4 etsityn sanan. Etsii kent\u00e4st\u00e4 joka annettu kohdassa `searchby` (etsi t\u00e4\u00e4lt\u00e4).","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"name_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"username_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"username_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"email_includes":{"description":"Rajoita vastaus kohteisiin joissa sis\u00e4llytet\u00e4\u00e4n s\u00e4hk\u00f6posteja.","type":"string","required":false},"email_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan s\u00e4hk\u00f6posteja.","type":"string","required":false},"country_includes":{"description":"Rajoita vastaus kohteisiin joissa tietyt maat.","type":"string","required":false},"country_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tietyt maat.","type":"string","required":false},"last_active_before":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_max":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_between":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on ennen tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on joko my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"users":{"description":"Limit result to items with specified user ids.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Suodata tulokset, joissa mik\u00e4 tahansa l\u00e4hetetyist\u00e4 kentist\u00e4 on tyhj\u00e4","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"include":{"description":"Rajoita tulokset kohteisiin joissa tietty asiakastunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/leaderboards":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Verkko-osoite\/URL kysely joka s\u00e4ilyy linkeiss\u00e4.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/leaderboards"}]}},"\/wc-analytics\/leaderboards\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/leaderboards\/allowed"}]}},"\/wc-analytics\/leaderboards\/(?P<leaderboard>\\w+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"leaderboard":{"type":"string","enum":["customers","coupons","categories","products"],"required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Verkko-osoite\/URL kysely joka s\u00e4ilyy linkeiss\u00e4.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/reports":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports"}]}},"\/wc-analytics\/reports\/import":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"days":{"description":"Tuotavien p\u00e4ivien lukum\u00e4\u00e4r\u00e4.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Ohita olemassa olevien tilausten tietojen tuonti.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/import"}]}},"\/wc-analytics\/reports\/import\/cancel":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/import\/cancel"}]}},"\/wc-analytics\/reports\/import\/delete":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/import\/delete"}]}},"\/wc-analytics\/reports\/import\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/import\/status"}]}},"\/wc-analytics\/reports\/import\/totals":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"days":{"description":"Tuotavien p\u00e4ivien lukum\u00e4\u00e4r\u00e4.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"Ohita olemassa olevien tilausten tietojen tuonti.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/import\/totals"}]}},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"report_args":{"description":"Viet\u00e4v\u00e4\u00e4n raporttiin sis\u00e4llytet\u00e4\u00e4n parametrit.","type":"object","required":false},"email":{"description":"Kun tosi, l\u00e4het\u00e4 s\u00e4hk\u00f6postilla viennin latauslinkki sit\u00e4 pyyt\u00e4neelle k\u00e4ytt\u00e4j\u00e4lle.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export\/(?P<export_id>[a-z0-9]+)\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/reports\/products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","product_name","variations","sku"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"categories":{"description":"Rajoita vastaus kohteisiin tietyist\u00e4 osastoista.","type":"array","items":{"type":"integer"},"required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"products":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 tuotetunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Lis\u00e4\u00e4 tieto jokaisesta tuotteesta raporttiin.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/products"}]}},"\/wc-analytics\/reports\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","sku"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limit result set to items that have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 muunnelman tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Add additional piece of info about each variation to the report.","type":"boolean","default":false,"required":false},"attribute_is":{"description":"Limit result set to variations that include the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to variations that don't include the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"category_includes":{"description":"Limit result set to variations in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limit result set to variations not in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 tuotetunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/variations"}]}},"\/wc-analytics\/reports\/products\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"categories":{"description":"Rajoita vastaus kohteisiin tietyist\u00e4 osastoista.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 tuotetunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"variations":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 muunnelman tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["product","category","variation"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/products\/stats"}]}},"\/wc-analytics\/reports\/variations\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"category_includes":{"description":"Rajoita vastaus kohteisiin tietyist\u00e4 osastoista.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limit result set to variations not in the specified categories.","type":"array","items":{"type":"integer"},"required":false},"product_includes":{"description":"Limit result set to items that have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limit result set to items that don't have the specified parent product(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Rajoita vastaus kohteisiin joilla on tiettyj\u00e4 muunnelman tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["product","category","variation"],"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/variations\/stats"}]}},"\/wc-analytics\/reports\/revenue\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","total_sales","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold","gross_sales"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"date_type":{"description":"Override the \"woocommerce_date_type\" option that is used for the database date field considered for revenue reports.","type":"string","enum":["date_paid","date_created","date_completed"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/revenue\/stats"}]}},"\/wc-analytics\/reports\/orders":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","num_items_sold","net_total"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"product_includes":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu tietty tuote(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Rajoita vastaus kohteisiin joihin ei ole kohdistettu tietty\u00e4 tuotetta(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limit result set to items that have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limit result set to items that don't have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Rajoita vastaus kohteisiin joille on kohdistettu tietty kuponki.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Rajoita vastaus kohteisiin joille ei ole kohdistettu tietty\u00e4 kuponkia.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Rajoita vastaus kohteisiin joille on kohdistettu tietty veron m\u00e4\u00e4r\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Rajoita vastaus kohteisiin joille ei ole kohdistettu tietty\u00e4 veron m\u00e4\u00e4r\u00e4\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status_is":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tila.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tilaa.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"customer_type":{"description":"Rajoita vastaus joko toistuviin tai uusiin asiakkaisiin.","type":"string","default":"","enum":["","returning","new"],"required":false},"refunds":{"description":"Rajoita vastaus tietynlaisiin hyvityksiin.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"extended_info":{"description":"Lis\u00e4\u00e4 tieto jokaisesta kupongista raporttiin.","type":"boolean","default":false,"required":false},"order_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tunnusta\/ID.","type":"array","items":{"type":"integer"},"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/orders"}]}},"\/wc-analytics\/reports\/orders\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","net_revenue","orders_count","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"status_is":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tila.","type":"array","default":null,"items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tilaa.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"product_includes":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu tietty tuote(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Rajoita vastaus kohteisiin joihin ei ole kohdistettu tietty\u00e4 tuotetta(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limit result set to items that have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limit result set to items that don't have the specified variation(s) assigned.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Rajoita vastaus kohteisiin joille on kohdistettu tietty kuponki.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Rajoita vastaus kohteisiin joille ei ole kohdistettu tietty\u00e4 kuponkia.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Rajoita vastaus kohteisiin joille on kohdistettu tietty veron m\u00e4\u00e4r\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Rajoita vastaus kohteisiin joille ei ole kohdistettu tietty\u00e4 veron m\u00e4\u00e4r\u00e4\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"customer":{"description":"Alias for customer_type (deprecated).","type":"string","enum":["new","returning"],"required":false},"customer_type":{"description":"Limit result set to orders that have the specified customer_type","type":"string","enum":["new","returning"],"required":false},"refunds":{"description":"Rajoita vastaus tietynlaisiin hyvityksiin.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"attribute_is":{"description":"Limit result set to orders that include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limit result set to orders that don't include products with the specified attributes.","type":"array","items":{"type":"array"},"default":[],"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/orders\/stats"}]}},"\/wc-analytics\/reports\/categories":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"category_id","enum":["category_id","items_sold","net_revenue","orders_count","products_count","category"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"status_is":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tila.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tilaa.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"categories":{"description":"Rajoita vastaus kaikkiin kohteisiin joihin on kohdistettu tietty termi osastojen luokittelussa.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Lis\u00e4\u00e4 tieto jokaisesta osastosta raporttiin.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/categories"}]}},"\/wc-analytics\/reports\/taxes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"tax_rate_id","enum":["name","tax_rate_id","tax_code","rate","order_tax","total_tax","shipping_tax","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"taxes":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu yksi tai useampi vero.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/taxes"}]}},"\/wc-analytics\/reports\/taxes\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","items_sold","total_sales","orders_count","products_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"taxes":{"description":"Rajoita vastaus kaikkiin kohteisiin joihin on kohdistettu tietty termi verojen luokittelussa.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["tax_rate_id"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/taxes\/stats"}]}},"\/wc-analytics\/reports\/coupons":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"coupon_id","enum":["coupon_id","code","amount","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"coupons":{"description":"Rajoita vastaus kuponkeihin jotka on kohdistettu tiettyjen kuponkien tunnukseen\/ID.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"Lis\u00e4\u00e4 tieto jokaisesta kupongista raporttiin.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/coupons"}]}},"\/wc-analytics\/reports\/coupons\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","amount","coupons_count","orders_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"coupons":{"description":"Rajoita vastaus kuponkeihin jotka on kohdistettu tiettyjen kuponkien tunnukseen\/ID.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Jaa vastaus osiin lis\u00e4rajoitteella.","type":"string","enum":["product","variation","category","coupon"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/coupons\/stats"}]}},"\/wc-analytics\/reports\/stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"stock_status","enum":["stock_status","stock_quantity","date","id","include","title","sku"],"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu varastoraportin laji.","type":"string","default":"all","enum":["all","lowstock","instock","outofstock","onbackorder"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/stock"}]}},"\/wc-analytics\/reports\/stock\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/stock\/stats"}]}},"\/wc-analytics\/reports\/downloads":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","product"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: products, orders, username, ip_address.","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu tietty tuote(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Rajoita vastaus kohteisiin joihin ei ole kohdistettu tietty\u00e4 tuotetta(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tunnusta\/ID.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty k\u00e4ytt\u00e4j\u00e4n tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 k\u00e4ytt\u00e4j\u00e4n tunnusta\/ID.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty IP-osoite.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 IP-osoitetta.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/downloads"}]}},"\/wc-analytics\/reports\/downloads\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","download_count"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Aikav\u00e4li jota k\u00e4ytet\u00e4\u00e4n vastaustietojoukkojen (saapumisen) v\u00e4lill\u00e4.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu tietty tuote(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Rajoita vastaus kohteisiin joihin ei ole kohdistettu tietty\u00e4 tuotetta(tuotteita).","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty tilauksen tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 tilauksen tunnusta\/ID.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty asiakkaan tunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 asiakkaan tunnusta\/ID.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Rajoita vastaus kohteisiin joilla on tietty IP-osoite.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Rajoita vastaus kohteisiin joilla ei ole tietty\u00e4 IP-osoitetta.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/downloads\/stats"}]}},"\/wc-analytics\/reports\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"registered_before":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Rajoita vastaus kohteisiin joissa asiakas kentt\u00e4 sis\u00e4lt\u00e4\u00e4 etsityn sanan. Etsii kent\u00e4st\u00e4 joka annettu kohdassa `searchby` (etsi t\u00e4\u00e4lt\u00e4).","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"name_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"username_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"username_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"email_includes":{"description":"Rajoita vastaus kohteisiin joissa sis\u00e4llytet\u00e4\u00e4n s\u00e4hk\u00f6posteja.","type":"string","required":false},"email_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan s\u00e4hk\u00f6posteja.","type":"string","required":false},"country_includes":{"description":"Rajoita vastaus kohteisiin joissa tietyt maat.","type":"string","required":false},"country_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tietyt maat.","type":"string","required":false},"last_active_before":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_max":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_between":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on ennen tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on joko my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"customers":{"description":"Rajoita tulokset kohteisiin joissa tietty asiakastunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limit result to items with specified user ids.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Suodata tulokset, joissa mik\u00e4 tahansa l\u00e4hetetyist\u00e4 kentist\u00e4 on tyhj\u00e4","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limit result to items with specified user type.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Includes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"location_excludes":{"description":"Excludes customers by location (state, country). Provide a comma-separated list of locations. Each location can be a country code (e.g. GB) or combination of country and state (e.g. US:CA).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/customers"}]}},"\/wc-analytics\/reports\/customers\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"registered_before":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Rajoita tulokset kohteisiin jotka rekister\u00f6ity my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"match":{"description":"Ilmaisee pit\u00e4isik\u00f6 kaikkien olla tosi vastausjoukossa tai jos joku niist\u00e4 on riitt\u00e4v\u00e4. Etsint\u00e4 vaikuttaa seuraaviin parametreihin: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Rajoita vastaus kohteisiin joissa asiakas kentt\u00e4 sis\u00e4lt\u00e4\u00e4 etsityn sanan. Etsii kent\u00e4st\u00e4 joka annettu kohdassa `searchby` (etsi t\u00e4\u00e4lt\u00e4).","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"name_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 nimi\u00e4.","type":"string","required":false},"username_includes":{"description":"Rajoita vastaus kohteisiin joissa tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"username_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tiettyj\u00e4 k\u00e4ytt\u00e4j\u00e4tunnuksia.","type":"string","required":false},"email_includes":{"description":"Rajoita vastaus kohteisiin joissa sis\u00e4llytet\u00e4\u00e4n s\u00e4hk\u00f6posteja.","type":"string","required":false},"email_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan s\u00e4hk\u00f6posteja.","type":"string","required":false},"country_includes":{"description":"Rajoita vastaus kohteisiin joissa tietyt maat.","type":"string","required":false},"country_excludes":{"description":"Rajoita vastaus kohteisiin joissa sivuutetaan tietyt maat.","type":"string","required":false},"last_active_before":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia aiemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Rajoita vastaus kohteisiin jotka viimeksi aktiivisia kahden ISO8601 muodossa annetun p\u00e4iv\u00e4yksen v\u00e4lisen\u00e4 aikana.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_max":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"integer","required":false},"orders_count_between":{"description":"Rajoita vastaus kohteisiin joissa tilausten lukum\u00e4\u00e4r\u00e4 on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"total_spend_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen kokonaiskulutus on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on enemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_max":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on v\u00e4hemm\u00e4n kuin tai sama kuin annettu luku.","type":"number","required":false},"avg_order_value_between":{"description":"Rajoita vastaus kohteisiin joissa tilauksen keskim\u00e4\u00e4r\u00e4inen arvo on kahden annetun luvun v\u00e4liss\u00e4.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on ennen tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Rajoita vastaus kohteisiin joiden viimeisin tilaus on joko my\u00f6hemmin tai sama kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"customers":{"description":"Rajoita tulokset kohteisiin joissa tietty asiakastunnus\/ID.","type":"array","items":{"type":"integer"},"required":false},"fields":{"description":"Rajaa tilastojen kent\u00e4t m\u00e4\u00e4riteltyihin nimikkeisiin","type":"array","items":{"type":"string"},"required":false},"force_cache_refresh":{"description":"Force retrieval of fresh data instead of from the cache.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/customers\/stats"}]}},"\/wc-analytics\/imports\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/imports\/status"}]}},"\/wc-analytics\/imports\/trigger":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/imports\/trigger"}]}},"\/wc-analytics\/reports\/performance-indicators":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Rajoita vastaus tiettyihin raporttitilastoihin. Sallitut arvot: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/performance-indicators"}]}},"\/wc-analytics\/reports\/performance-indicators\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Rajoita vastaus tiettyihin raporttitilastoihin. Sallitut arvot: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/reports\/performance-indicators\/allowed"}]}},"\/wc-analytics\/admin\/notes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["note_id","date","type","title","status"],"required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"type":{"description":"Kommentin laji.","type":"array","items":{"enum":["error","warning","update","info","marketing","survey"],"type":"string"},"required":false},"status":{"description":"Kommentin tila.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"source":{"description":"Source of note.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/admin\/notes"}]}},"\/wc-analytics\/admin\/notes\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/all":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"description":"Kommentin tila.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/admin\/notes\/delete\/all"}]}},"\/wc-analytics\/admin\/notes\/tracker\/(?P<note_id>[\\d-]+)\/user\/(?P<user_id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/update":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/admin\/notes\/update"}]}},"\/wc-analytics\/admin\/notes\/experimental-activate-promo\/(?P<promo_note_name>[\\w-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/(?P<note_id>[\\d-]+)\/action\/(?P<action_id>[\\d-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"note_id":{"description":"Muista poikkava tunnus\/ID kommentille.","type":"integer","required":false},"action_id":{"description":"Muista poikkava tunnus\/ID muistioon reagoinnille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/coupons":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita vastaus kuponkeihin joiden koodi vastaa tietty\u00e4 merkkijonoa.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty koodi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":true},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/coupons"}]}},"\/wc-analytics\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/coupons\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/coupons\/batch"}]}},"\/wc-analytics\/data":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/data"}]}},"\/wc-analytics\/data\/countries\/locales":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/data\/countries\/locales"}]}},"\/wc-analytics\/data\/countries":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/data\/countries"}]}},"\/wc-analytics\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO3166 alpha-2 maatunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/data\/download-ips":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/data\/download-ips"}]}},"\/wc-analytics\/orders":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":["any"],"description":"Rajoita tulosjoukko tilauksiin joilla on tietty tila.","type":"array","items":{"type":"string","enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty asiakas.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty tuote.","type":"integer","required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limit result set to orders created via specific sources (e.g. checkout, admin).","type":"array","items":{"type":"string"},"required":false},"number":{"description":"Rajoita vastaus tilauksiin jotka vastaavat osaa tilausnumerosta.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"default":"pending","description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/orders"}]}},"\/wc-analytics\/orders\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/orders\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/orders\/batch"}]}},"\/wc-analytics\/products":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Etsi samanlaisen tuoteninen tai tuotetunnuksen\/SKU mukaan.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limit results to those with a SKU that partial matches a string. This argument takes precedence over 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limit results to those with a name or SKU that partial matches a string. This argument takes precedence over 'search', 'sku' and 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limit search to specific fields when used with search parameter. Available fields: name, sku, global_unique_id, description, short_description. This argument takes precedence over all other search parameters.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limit result set to products with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude products with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limit result set to products with any of the types.","type":"array","items":{"type":"string","enum":["simple","variable"]},"required":false},"exclude_types":{"description":"Exclude products with any of the types from result set.","type":"array","items":{"type":"string","enum":["simple","variable"]},"required":false},"downloadable":{"description":"Limit result set to downloadable products.","type":"boolean","required":false},"virtual":{"description":"Limit result set to virtual products.","type":"boolean","required":false},"pos_products_only":{"description":"Limit result set to products visible in Point of Sale.","type":"boolean","required":false},"low_in_stock":{"description":"Limit result set to products that are low or out of stock. (Deprecated)","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"default":"publish","description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"description":"Ohitetaanko roskakori ja pakotetaan poisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/batch"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/suggested-products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Rajoita tuotteiden tulosjoukko varastossa tai loppu varastosta mukaan.","type":"boolean","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limit result set to specific product categorie ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limit result set to specific product tag ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limit result set to specific amount of suggested products.","type":"integer","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/suggested-products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"search":{"description":"Search by similar attribute name.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Resurssin nimi.","type":"string","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"default":"select","description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/attributes"}]}},"\/wc-analytics\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/attributes\/batch"}]}},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug identifier for the resource.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)\/terms":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/categories":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/categories"}]}},"\/wc-analytics\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/categories\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/categories\/batch"}]}},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Search by similar product name, sku, or attribute value.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Ominaisuuden polkutunnus."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"type":{"default":"variation","description":"Tuotteen laji.","type":"string","enum":["variation"],"required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"name":{"description":"Tuotteen ylemm\u00e4n tason nimi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["variation"],"required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"name":{"description":"Tuotteen ylemm\u00e4n tason nimi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["variation"],"required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"name":{"description":"Tuotteen ylemm\u00e4n tason nimi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"delete":{"description":"Poistaa k\u00e4ytt\u00e4m\u00e4tt\u00f6m\u00e4t muunnelmat.","type":"boolean","required":false},"default_values":{"description":"Default values for generated variations.","type":"object","properties":{"type":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tuotteen laji.","type":"string","enum":["variation"]},"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman kuvaus","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock Keeping Unit.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN tai ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman tavallinen hinta.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman alennettu hinta.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos muunnelma on palvelu.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos muunnelma on ladattava.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Veroluokka.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Low Stock amount for the variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman paino (g (gramma)).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Toimitusluokan polkutunnus.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"parent_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer"},"variation_quantity_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"]},"group_of_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Require variations to be purchased in multiples of this value.","type":"integer"},"min_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Minimum required variation quantity.","type":"integer"},"max_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Maximum allowed variation quantity.","type":["integer","string"]},"exclude_order_quantity_value_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"]},"exclude_category_quantity_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"]},"name":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tuotteen ylemm\u00e4n tason nimi.","type":"string"}},"required":false},"type":{"default":"variation","description":"Tuotteen laji.","type":"string","enum":["variation"],"required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"name":{"description":"Tuotteen ylemm\u00e4n tason nimi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Search by similar product name, sku, or attribute value.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Ominaisuuden polkutunnus."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/variations"}]}},"\/wc-analytics\/products\/reviews":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus arviointeihin jotka julkaistu ennen annettua p\u00e4iv\u00e4yst\u00e4 ISO8601 muodossa.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Rajoita arviointien tulosjoukko tietyn k\u00e4ytt\u00e4j\u00e4tunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois arvioinnit tietyn k\u00e4ytt\u00e4j\u00e4tunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Rajoita tulosjoukko tietyn kirjoittajan s\u00e4hk\u00f6postin mukaan.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Rajoita arviointien tulosjoukko tietyn tuotetunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Rajoita arviointien tulosjoukko tietyn tilan mukaan.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste tuotteelle.","type":"integer","required":true},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"default":"approved","description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Arvioijan nimi.","required":true},"reviewer_email":{"type":"string","description":"Arvioijan s\u00e4hk\u00f6postiosoite.","required":true},"review":{"type":"string","description":"Arvion sis\u00e4lt\u00f6.","required":true},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/reviews"}]}},"\/wc-analytics\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"product_id":{"description":"Tuotteen muista poikkeava tunnus jota arviointi koskee.","type":"integer","required":false},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Arvioijan nimi.","type":"string","required":false},"reviewer_email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/products\/reviews\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Tuotteen muista poikkeava tunnus jota arviointi koskee.","type":"integer","required":false},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Arvioijan nimi.","type":"string","required":false},"reviewer_email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/reviews\/batch"}]}},"\/wc-analytics\/products\/low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"status":{"default":"publish","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/low-in-stock"}]}},"\/wc-analytics\/products\/count-low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"status":{"default":"publish","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/products\/count-low-in-stock"}]}},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/taxes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"J\u00e4rjest\u00e4 veroluokan mukaan.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"search":{"description":"Etsi saman verokoodin perusteella.","type":"string","required":false},"include":{"description":"Rajoita vastaus kohteisiin joihin on kohdistettu tietty veron m\u00e4\u00e4r\u00e4n tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"default":1,"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"default":false,"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"default":true,"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"default":"standard","description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/taxes"}]}},"\/wc-analytics\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-analytics\/taxes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-analytics\/taxes\/batch"}]}},"\/wc-admin\/launch-your-store\/initialize-coming-soon":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/launch-your-store\/initialize-coming-soon"}]}},"\/wc-admin\/launch-your-store\/update-survey-status":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"status":{"type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/launch-your-store\/update-survey-status"}]}},"\/wc-admin\/launch-your-store\/survey-completed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/launch-your-store\/survey-completed"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders":{"namespace":"wc-admin","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders"}]}},"\/wc\/store":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store"}]}},"\/wc\/store\/batch":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/batch"}]}},"\/wc\/store\/cart":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart"}]}},"\/wc\/store\/cart\/add-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Ostoskorin kohteen tuote- tai muunnelma tunnus\/ID.","type":"integer","required":false},"quantity":{"description":"Ostoskoriin lis\u00e4tt\u00e4v\u00e4 tuotteiden lukum\u00e4\u00e4r\u00e4.","type":"number","required":false},"variation":{"description":"Valitut ominaisuudet (muunnelmille).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Muunnelman ominaisuuden nimi.","type":"string","context":["view","edit"]},"value":{"description":"Muunnelman ominaisuuden arvo.","type":"string","context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/add-item"}]}},"\/wc\/store\/cart\/apply-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/apply-coupon"}]}},"\/wc\/store\/cart\/coupons":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Kupongin uniikki koodi.","type":"string","required":false},"discount_type":{"description":"Kupongin alennustyyppi (esim. prosenttiosuus tai kiinte\u00e4 summa)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/coupons"}]}},"\/wc\/store\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/cart\/extensions":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Extension's name - this will be used to ensure the data in the request is routed appropriately.","type":"string","required":false},"data":{"description":"Additional data to pass to the extension","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/extensions"}]}},"\/wc\/store\/cart\/items":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/items"}]}},"\/wc\/store\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/cart\/remove-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/remove-coupon"}]}},"\/wc\/store\/cart\/remove-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Ostoskorin tuotteen yksil\u00f6llinen tunnus (key).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/remove-item"}]}},"\/wc\/store\/cart\/select-shipping-rate":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"The ID of the package being shipped. Leave blank to apply to all packages.","type":["integer","string","null"],"required":false},"rate_id":{"description":"Valittu kustannus-ID paketille.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/select-shipping-rate"}]}},"\/wc\/store\/cart\/update-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Ostoskorin p\u00e4ivitett\u00e4v\u00e4n tuotteen yksil\u00f6llinen tunnus (key).","type":"string","required":false},"quantity":{"description":"Uusi tuotteen m\u00e4\u00e4r\u00e4 ostoskorissa.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/update-item"}]}},"\/wc\/store\/cart\/update-customer":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/cart\/update-customer"}]}},"\/wc\/store\/checkout":{"namespace":"wc\/store","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Maksutavan l\u00e4pi kulkeva data, kun maksutapahtumaa k\u00e4sitell\u00e4\u00e4n.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Customer password for new accounts, if applicable.","type":"string","required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"order_notes":{"description":"Tilauksen kommentit.","type":"string","required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/checkout"}]}},"\/wc\/store\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Maksutavan l\u00e4pi kulkeva data, kun maksutapahtumaa k\u00e4sitell\u00e4\u00e4n.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/attributes":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/attributes"}]}},"\/wc\/store\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Muista poikkeava tunniste ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/categories":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/categories"}]}},"\/wc\/store\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/brands":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/brands"}]}},"\/wc\/store\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/collection-data":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko tuotteisiin, joissa on tiettyj\u00e4 polkutunnuksia. K\u00e4yt\u00e4 pilkkuja erottaaksesi.","type":"string","required":false},"after":{"description":"Rajoita vastaus resursseihin, jotka julkaistiin annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus resursseihin jotka luotu aiemmin kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"date_column":{"description":"Kun rajoitetaan vastaus k\u00e4ytt\u00e4en aiemmin\/my\u00f6hemmin, mit\u00e4 p\u00e4iv\u00e4ys saraketta vasten verrataan.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable","variation"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko kategoria-ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuina.","type":"string","required":false},"category_operator":{"description":"Toiminto jolla voidaan verrata tuoteosastojen termej\u00e4.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tuotemerkkien ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"brand_operator":{"description":"Operaattori tuotteen br\u00e4ndin arvojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tunnisteita tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"tag_operator":{"description":"Operaattori tuotteen avainsanojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille minimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"max_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille maksimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Rajoita vastaus tuotteisiin joilla valitut globaalit ominaisuudet.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Ominaisuuden luokittelu nimi.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Luettelo ominaisuuden termien tunnuksista\/ID.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Luettelo ominaisuuden polkutunnuksista. Jos termin tunnus\/ID annettu, se sivuutetaan.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Toiminto jolla voidaan verrata tuoteominaisuuksien termej\u00e4.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Ominaisuuksien v\u00e4linen looginen suhde kun suodatetaan usean yli kerralla.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"M\u00e4\u00e4r\u00e4\u00e4 n\u00e4ytet\u00e4\u00e4nk\u00f6 tuoteluettelon piilotetut vai n\u00e4kyvill\u00e4 olevat tuoteet.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Rajoita vastaus tuotteisiin joilla tietty keskim\u00e4\u00e4r\u00e4inen arvostelu.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"Jos tosi, laskee kokoelmalle minimi ja maksimi hinnat.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Jos tosi, laskee tuotteiden varastotilanteen kokoelmassa.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Jos pyydet\u00e4\u00e4n, laskee ominaisuuden termien lukum\u00e4\u00e4r\u00e4n kokoelmassa.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Luokittelun nimi.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Suoritettavan kyselyn laji joka voi vaikuttaa lukum\u00e4\u00e4riin. Arvot \"and\" ja\"or\" kelpaavat.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"Jos tosi, laskee tuotteiden arvostelujen lukum\u00e4\u00e4r\u00e4n kokoelmassa.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"If requested, calculates taxonomy term counts for products in the collection.","type":"array","items":{"type":"string","description":"Luokittelun nimi."},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/collection-data"}]}},"\/wc\/store\/products\/reviews":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Rajaa tulokset arvosteluihin, joilla on tiettyjen kategorioiden ID:t.","type":"string","required":false},"product_id":{"description":"Rajaa tulokset arvosteluihin, joilla on tiettyjen tuotteiden ID:t.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/reviews"}]}},"\/wc\/store\/products\/tags":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products\/tags"}]}},"\/wc\/store\/products":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko tuotteisiin, joissa on tiettyj\u00e4 polkutunnuksia. K\u00e4yt\u00e4 pilkkuja erottaaksesi.","type":"string","required":false},"after":{"description":"Rajoita vastaus resursseihin, jotka julkaistiin annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus resursseihin jotka luotu aiemmin kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"date_column":{"description":"Kun rajoitetaan vastaus k\u00e4ytt\u00e4en aiemmin\/my\u00f6hemmin, mit\u00e4 p\u00e4iv\u00e4ys saraketta vasten verrataan.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable","variation"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko kategoria-ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuina.","type":"string","required":false},"category_operator":{"description":"Toiminto jolla voidaan verrata tuoteosastojen termej\u00e4.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tuotemerkkien ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"brand_operator":{"description":"Operaattori tuotteen br\u00e4ndin arvojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tunnisteita tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"tag_operator":{"description":"Operaattori tuotteen avainsanojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille minimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"max_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille maksimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Rajoita vastaus tuotteisiin joilla valitut globaalit ominaisuudet.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Ominaisuuden luokittelu nimi.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Luettelo ominaisuuden termien tunnuksista\/ID.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Luettelo ominaisuuden polkutunnuksista. Jos termin tunnus\/ID annettu, se sivuutetaan.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Toiminto jolla voidaan verrata tuoteominaisuuksien termej\u00e4.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Ominaisuuksien v\u00e4linen looginen suhde kun suodatetaan usean yli kerralla.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"M\u00e4\u00e4r\u00e4\u00e4 n\u00e4ytet\u00e4\u00e4nk\u00f6 tuoteluettelon piilotetut vai n\u00e4kyvill\u00e4 olevat tuoteet.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Rajoita vastaus tuotteisiin joilla tietty keskim\u00e4\u00e4r\u00e4inen arvostelu.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/products"}]}},"\/wc\/store\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Resurssin polkutunnus.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1"}]}},"\/wc\/store\/v1\/batch":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/batch"}]}},"\/wc\/store\/v1\/cart":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart"}]}},"\/wc\/store\/v1\/cart\/add-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Ostoskorin kohteen tuote- tai muunnelma tunnus\/ID.","type":"integer","required":false},"quantity":{"description":"Ostoskoriin lis\u00e4tt\u00e4v\u00e4 tuotteiden lukum\u00e4\u00e4r\u00e4.","type":"number","required":false},"variation":{"description":"Valitut ominaisuudet (muunnelmille).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Muunnelman ominaisuuden nimi.","type":"string","context":["view","edit"]},"value":{"description":"Muunnelman ominaisuuden arvo.","type":"string","context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/add-item"}]}},"\/wc\/store\/v1\/cart\/apply-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/apply-coupon"}]}},"\/wc\/store\/v1\/cart\/coupons":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Kupongin uniikki koodi.","type":"string","required":false},"discount_type":{"description":"Kupongin alennustyyppi (esim. prosenttiosuus tai kiinte\u00e4 summa)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/coupons"}]}},"\/wc\/store\/v1\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/cart\/extensions":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Extension's name - this will be used to ensure the data in the request is routed appropriately.","type":"string","required":false},"data":{"description":"Additional data to pass to the extension","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/extensions"}]}},"\/wc\/store\/v1\/cart\/items":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":[],"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/items"}]}},"\/wc\/store\/v1\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"extensions":{"type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kohteelle.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/cart\/remove-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Muista poikkeava tunniste ostoskorissa olevalle kupongille.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/remove-coupon"}]}},"\/wc\/store\/v1\/cart\/remove-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Ostoskorin tuotteen yksil\u00f6llinen tunnus (key).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/remove-item"}]}},"\/wc\/store\/v1\/cart\/select-shipping-rate":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"The ID of the package being shipped. Leave blank to apply to all packages.","type":["integer","string","null"],"required":false},"rate_id":{"description":"Valittu kustannus-ID paketille.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/select-shipping-rate"}]}},"\/wc\/store\/v1\/cart\/update-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Ostoskorin p\u00e4ivitett\u00e4v\u00e4n tuotteen yksil\u00f6llinen tunnus (key).","type":"string","required":false},"quantity":{"description":"Uusi tuotteen m\u00e4\u00e4r\u00e4 ostoskorissa.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/update-item"}]}},"\/wc\/store\/v1\/cart\/update-customer":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/cart\/update-customer"}]}},"\/wc\/store\/v1\/checkout":{"namespace":"wc\/store\/v1","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Maksutavan l\u00e4pi kulkeva data, kun maksutapahtumaa k\u00e4sitell\u00e4\u00e4n.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Customer password for new accounts, if applicable.","type":"string","required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"order_notes":{"description":"Tilauksen kommentit.","type":"string","required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Whether to create a new user account as part of order processing.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/checkout"}]}},"\/wc\/store\/v1\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Maksutavan l\u00e4pi kulkeva data, kun maksutapahtumaa k\u00e4sitell\u00e4\u00e4n.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Asiakkaan tilaukseen kassalla lis\u00e4\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing_address":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true},"email":{"description":"S\u00e4hk\u00f6posti","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Sukunimi","type":"string","context":["view","edit"],"required":true},"company":{"description":"Yritys","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Osoite","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Huoneisto, yksikk\u00f6, jne.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Kaupunki","type":"string","context":["view","edit"],"required":true},"state":{"description":"Osavaltion\/maakunnan koodi tai osavaltion nimi, piirikunnan, provinssin tai alueen nimi.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"Postinumero","type":"string","context":["view","edit"],"required":true},"country":{"description":"Maa-\/Aluekoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Puhelin","type":"string","context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"Maksun k\u00e4sittelyss\u00e4 k\u00e4ytett\u00e4v\u00e4n maksutavan tunniste.","type":"string","enum":["","paytrail","stripe","stripe_blik","stripe_eps","stripe_bancontact","stripe_ideal","stripe_sepa_debit","stripe_p24","stripe_link","stripe_klarna","bacs","cheque","cod","stripe_us_bank_account","stripe_alipay","stripe_amazon_pay","stripe_affirm","stripe_afterpay_clearpay","stripe_boleto","stripe_oxxo","stripe_multibanco","stripe_wechat_pay","stripe_cashapp","stripe_acss_debit","stripe_bacs_debit","stripe_au_becs_debit"],"required":false},"additional_fields":{"description":"Additional fields to be persisted on the order.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"woocommerce\/order-attribution":{"description":"Extension data registered by woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Order attribution field: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Order attribution field: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Order attribution field: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Order attribution field: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Order attribution field: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Order attribution field: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Order attribution field: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Order attribution field: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Order attribution field: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Order attribution field: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Order attribution field: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Order attribution field: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Order attribution field: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Order attribution field: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Order attribution field: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Order attribution field: user_agent","type":["string","null"],"context":[]}}}},"default":{"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/attributes":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/attributes"}]}},"\/wc\/store\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Muista poikkeava tunniste ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/categories":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/categories"}]}},"\/wc\/store\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/brands":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/brands"}]}},"\/wc\/store\/v1\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/collection-data":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko tuotteisiin, joissa on tiettyj\u00e4 polkutunnuksia. K\u00e4yt\u00e4 pilkkuja erottaaksesi.","type":"string","required":false},"after":{"description":"Rajoita vastaus resursseihin, jotka julkaistiin annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus resursseihin jotka luotu aiemmin kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"date_column":{"description":"Kun rajoitetaan vastaus k\u00e4ytt\u00e4en aiemmin\/my\u00f6hemmin, mit\u00e4 p\u00e4iv\u00e4ys saraketta vasten verrataan.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable","variation"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko kategoria-ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuina.","type":"string","required":false},"category_operator":{"description":"Toiminto jolla voidaan verrata tuoteosastojen termej\u00e4.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tuotemerkkien ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"brand_operator":{"description":"Operaattori tuotteen br\u00e4ndin arvojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tunnisteita tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"tag_operator":{"description":"Operaattori tuotteen avainsanojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille minimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"max_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille maksimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Rajoita vastaus tuotteisiin joilla valitut globaalit ominaisuudet.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Ominaisuuden luokittelu nimi.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Luettelo ominaisuuden termien tunnuksista\/ID.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Luettelo ominaisuuden polkutunnuksista. Jos termin tunnus\/ID annettu, se sivuutetaan.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Toiminto jolla voidaan verrata tuoteominaisuuksien termej\u00e4.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Ominaisuuksien v\u00e4linen looginen suhde kun suodatetaan usean yli kerralla.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"M\u00e4\u00e4r\u00e4\u00e4 n\u00e4ytet\u00e4\u00e4nk\u00f6 tuoteluettelon piilotetut vai n\u00e4kyvill\u00e4 olevat tuoteet.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Rajoita vastaus tuotteisiin joilla tietty keskim\u00e4\u00e4r\u00e4inen arvostelu.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"calculate_price_range":{"description":"Jos tosi, laskee kokoelmalle minimi ja maksimi hinnat.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Jos tosi, laskee tuotteiden varastotilanteen kokoelmassa.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Jos pyydet\u00e4\u00e4n, laskee ominaisuuden termien lukum\u00e4\u00e4r\u00e4n kokoelmassa.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Luokittelun nimi.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Suoritettavan kyselyn laji joka voi vaikuttaa lukum\u00e4\u00e4riin. Arvot \"and\" ja\"or\" kelpaavat.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"required":false},"calculate_rating_counts":{"description":"Jos tosi, laskee tuotteiden arvostelujen lukum\u00e4\u00e4r\u00e4n kokoelmassa.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"If requested, calculates taxonomy term counts for products in the collection.","type":"array","items":{"type":"string","description":"Luokittelun nimi."},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/collection-data"}]}},"\/wc\/store\/v1\/products\/reviews":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Rajaa tulokset arvosteluihin, joilla on tiettyjen kategorioiden ID:t.","type":"string","required":false},"product_id":{"description":"Rajaa tulokset arvosteluihin, joilla on tiettyjen tuotteiden ID:t.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/reviews"}]}},"\/wc\/store\/v1\/products\/tags":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Laita nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele termiominaisuuden mukaan.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Jos valittuna, tyhji\u00e4 termej\u00e4 ei palauteta.","type":"boolean","default":true,"required":false},"parent":{"description":"Limit results to terms with a specific parent (hierarchical taxonomies only).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products\/tags"}]}},"\/wc\/store\/v1\/products":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Palautetun tuotejoukon enimm\u00e4ism\u00e4\u00e4r\u00e4. Oletusarvona on rajaton, jos t\u00e4m\u00e4 j\u00e4tet\u00e4\u00e4n tyhj\u00e4ksi.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko tuotteisiin, joissa on tiettyj\u00e4 polkutunnuksia. K\u00e4yt\u00e4 pilkkuja erottaaksesi.","type":"string","required":false},"after":{"description":"Rajoita vastaus resursseihin, jotka julkaistiin annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus resursseihin jotka luotu aiemmin kuin p\u00e4iv\u00e4ys annettuna ISO8601 muodossa.","type":"string","format":"date-time","required":false},"date_column":{"description":"Kun rajoitetaan vastaus k\u00e4ytt\u00e4en aiemmin\/my\u00f6hemmin, mit\u00e4 p\u00e4iv\u00e4ys saraketta vasten verrataan.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable","variation"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko kategoria-ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuina.","type":"string","required":false},"category_operator":{"description":"Toiminto jolla voidaan verrata tuoteosastojen termej\u00e4.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tuotemerkkien ID:it\u00e4 tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"brand_operator":{"description":"Operaattori tuotteen br\u00e4ndin arvojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin, joille on m\u00e4\u00e4ritetty joukko tunnisteita tai polkutunnuksia pilkuilla erotettuna.","type":"string","required":false},"tag_operator":{"description":"Operaattori tuotteen avainsanojen vertailuun.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille minimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"max_price":{"description":"Rajoita tulosten m\u00e4\u00e4r\u00e4\u00e4 tuotteille maksimihinnan mukaan, k\u00e4ytt\u00e4en valuutan pienint\u00e4 yksikk\u00f6\u00e4.","type":"string","required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Rajoita vastaus tuotteisiin joilla valitut globaalit ominaisuudet.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Ominaisuuden luokittelu nimi.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Luettelo ominaisuuden termien tunnuksista\/ID.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Luettelo ominaisuuden polkutunnuksista. Jos termin tunnus\/ID annettu, se sivuutetaan.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Toiminto jolla voidaan verrata tuoteominaisuuksien termej\u00e4.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"Ominaisuuksien v\u00e4linen looginen suhde kun suodatetaan usean yli kerralla.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"M\u00e4\u00e4r\u00e4\u00e4 n\u00e4ytet\u00e4\u00e4nk\u00f6 tuoteluettelon piilotetut vai n\u00e4kyvill\u00e4 olevat tuoteet.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Rajoita vastaus tuotteisiin joilla tietty keskim\u00e4\u00e4r\u00e4inen arvostelu.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/store\/v1\/products"}]}},"\/wc\/store\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/store\/v1\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Resurssin polkutunnus.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n ulottuma; m\u00e4\u00e4ritt\u00e4\u00e4 vastauksessa olevat kent\u00e4t.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/private":{"namespace":"wc\/private","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/private","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/private"}]}},"\/wc\/private\/patterns":{"namespace":"wc\/private","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/private\/patterns"}]}},"\/wp-2fa-methods\/v1":{"namespace":"wp-2fa-methods\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-2fa-methods\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-2fa-methods\/v1"}]}},"\/wp-2fa-passkeys\/v1":{"namespace":"wp-2fa-passkeys\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-2fa-passkeys\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-2fa-passkeys\/v1"}]}},"\/wp-2fa-passkeys\/v1\/register\/response":{"namespace":"wp-2fa-passkeys\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-2fa-passkeys\/v1\/register\/response"}]}},"\/yaysmtp\/v1":{"namespace":"yaysmtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yaysmtp\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/yaysmtp\/v1"}]}},"\/yaysmtp\/v1\/track-event\/(?P<resources>.+)":{"namespace":"yaysmtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"resources":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2"}]}},"\/wc\/v2\/products\/brands":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/brands"}]}},"\/wc\/v2\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/brands\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/brands\/batch"}]}},"\/wc\/v3\/products\/brands":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/brands"}]}},"\/wc\/v3\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/brands\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/brands\/batch"}]}},"\/adtribes\/v1":{"namespace":"adtribes\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"adtribes\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/adtribes\/v1"}]}},"\/adtribes\/v1\/pfp":{"namespace":"adtribes\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/adtribes\/v1\/pfp"}]}},"\/adtribes\/v1\/filters-rules\/(?P<feed_id>[\\w-]+)":{"namespace":"adtribes\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/ruuvi\/v1":{"namespace":"ruuvi\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ruuvi\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/ruuvi\/v1"}]}},"\/ruuvi\/v1\/subscription-settings":{"namespace":"ruuvi\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/ruuvi\/v1\/subscription-settings"}]}},"\/ruuvi\/v1\/unsubscribe":{"namespace":"ruuvi\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/ruuvi\/v1\/unsubscribe"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Whether to only regenerate missing thumbnails. It's faster with this enabled.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Whether to delete any old, now unregistered thumbnail files.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Whether to update the image tags in any posts that make use of this attachment.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"The types of posts to update. Defaults to all public post types.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Specific post IDs to update rather than any posts that use this attachment.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Posts to process per loop. This is to control memory usage and you likely don't need to adjust this.","type":"integer","default":10,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/wc\/v1\/coupons":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"K\u00e4yt\u00e4 WP Query -argumentteja vastauksen muuttamiseen; yksityiset kutsumuuttujat edellytt\u00e4v\u00e4t tarvittavaa valtuutusta.","required":false},"code":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty koodi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":true},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime -muodossa aika jolloin kupongin k\u00e4ytt\u00f6aika umpeutuu..","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/coupons"}]}},"\/wc\/v1\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"code":{"description":"Kupongin koodi.","type":"string","required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime -muodossa aika jolloin kupongin k\u00e4ytt\u00f6aika umpeutuu..","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/coupons\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":"string","required":false},"expiry_date":{"description":"UTC DateTime -muodossa aika jolloin kupongin k\u00e4ytt\u00f6aika umpeutuu..","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/coupons\/batch"}]}},"\/wc\/v1\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/customers":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Rajoita tulosjoukko resursseihin joissa on tietty s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"role":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty rooli.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","wpseo_manager","wpseo_editor","customer","shop_manager"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Uusi k\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","required":true},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Uusi k\u00e4ytt\u00e4j\u00e4nimi.","type":"string","required":false},"password":{"description":"Uusi salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/customers"}]}},"\/wc\/v1\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"reassign":{"default":0,"type":"integer","description":"Tunnus\/ID johon artikkeli kohdistetaan.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/customers\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/customers\/batch"}]}},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"note":{"type":"string","description":"Tilauksen kommentin sis\u00e4lt\u00f6.","required":true},"customer_note":{"default":false,"description":"N\u00e4ytt\u00e4\u00e4\/m\u00e4\u00e4rit\u00e4 jos kommentti on vain tiedoksi tai asiakasta varten (ilmoitetaan asiakkaalle).","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"K\u00e4yt\u00e4 WP Query -argumentteja vastauksen muuttamiseen; yksityiset kutsumuuttujat edellytt\u00e4v\u00e4t tarvittavaa valtuutusta.","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tilauksiin joilla on tietty tila.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty asiakas.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty tuote.","type":"integer","required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"amount":{"description":"Hyvityksen m\u00e4\u00e4r\u00e4.","type":"string","required":false},"reason":{"description":"Hyvityksen syy.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/orders":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"K\u00e4yt\u00e4 WP Query -argumentteja vastauksen muuttamiseen; yksityiset kutsumuuttujat edellytt\u00e4v\u00e4t tarvittavaa valtuutusta.","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tilauksiin joilla on tietty tila.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty asiakas.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty tuote.","type":"integer","required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"default":"pending","description":"Tilauksen tila.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"set_paid":{"default":false,"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Tuoterivien meta-tiedot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta-avain.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta-tunnus\/nimi.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/orders"}]}},"\/wc\/v1\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Tuoterivien meta-tiedot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta-avain.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta-tunnus\/nimi.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/orders\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2.","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Tuoterivien meta-tiedot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Meta-avain.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Meta-tunnus\/nimi.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/orders\/batch"}]}},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/attributes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Resurssin nimi.","type":"string","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"default":"select","description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/attributes"}]}},"\/wc\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/attributes\/batch"}]}},"\/wc\/v1\/products\/categories":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/categories"}]}},"\/wc\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/categories\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/categories\/batch"}]}},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"review":{"type":"string","description":"Arvion sis\u00e4lt\u00f6.","required":true},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuotearvio luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"name":{"type":"string","description":"Arvioijan nimi.","required":true},"email":{"type":"string","description":"Arvioijan s\u00e4hk\u00f6postiosoite.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuotearvio luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"name":{"description":"Arvioijan nimi.","type":"string","required":false},"email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/shipping_classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/shipping_classes"}]}},"\/wc\/v1\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/shipping_classes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/shipping_classes\/batch"}]}},"\/wc\/v1\/products\/tags":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/tags"}]}},"\/wc\/v1\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/tags\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/tags\/batch"}]}},"\/wc\/v1\/products":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"K\u00e4yt\u00e4 WP Query -argumentteja vastauksen muuttamiseen; yksityiset kutsumuuttujat edellytt\u00e4v\u00e4t tarvittavaa valtuutusta.","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty ominaisuus.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"sku":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tuotetunnus\/SKU.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"default":"simple","description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"default":"publish","description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","required":false},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","required":false},"virtual":{"default":false,"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"download_type":{"default":"standard","description":"Latauksen laji, t\u00e4ll\u00e4 m\u00e4\u00e4ritet\u00e4\u00e4n malli julkisella puolella.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"default":true,"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista 'parempi tuote' tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Muunnelmien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Muunnelman tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin muunnelma luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin muunnelmaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Muunnelman verkko-osoite.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Muista poikkeava tunniste.","type":"string","context":["view","edit"]},"price":{"description":"Nykyinen muunnelman hinta.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","context":["view","edit"]},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","context":["view","edit"]},"on_sale":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on alennuksessa.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelman voi ostaa.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Jos muunnelma n\u00e4ytet\u00e4\u00e4n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Veron tila.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Veroluokka.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"N\u00e4ytt\u00e4\u00e4 sallitaanko j\u00e4lkitoimitukset.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on j\u00e4lkitoimituksessa.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","context":["view","edit"]},"dimensions":{"description":"Muunnelman mitat.","type":"object","context":["view","edit"],"properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Toimitusluokan tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Ominisuuksien lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products"}]}},"\/wc\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","required":false},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"download_type":{"description":"Latauksen laji, t\u00e4ll\u00e4 m\u00e4\u00e4ritet\u00e4\u00e4n malli julkisella puolella.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista 'parempi tuote' tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Muunnelmien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Muunnelman tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin muunnelma luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin muunnelmaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Muunnelman verkko-osoite.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Muista poikkeava tunniste.","type":"string","context":["view","edit"]},"price":{"description":"Nykyinen muunnelman hinta.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","context":["view","edit"]},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","context":["view","edit"]},"on_sale":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on alennuksessa.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelman voi ostaa.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Jos muunnelma n\u00e4ytet\u00e4\u00e4n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Veron tila.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Veroluokka.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"N\u00e4ytt\u00e4\u00e4 sallitaanko j\u00e4lkitoimitukset.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on j\u00e4lkitoimituksessa.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","context":["view","edit"]},"dimensions":{"description":"Muunnelman mitat.","type":"object","context":["view","edit"],"properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Toimitusluokan tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Ominisuuksien lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"description":"Ohitetaanko roskakori ja pakotetaan poisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/products\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","required":false},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"download_type":{"description":"Latauksen laji, t\u00e4ll\u00e4 m\u00e4\u00e4ritet\u00e4\u00e4n malli julkisella puolella.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista 'parempi tuote' tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Muunnelmien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Muunnelman tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin muunnelma luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin muunnelmaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"Muunnelman verkko-osoite.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Muista poikkeava tunniste.","type":"string","context":["view","edit"]},"price":{"description":"Nykyinen muunnelman hinta.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","context":["view","edit"]},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Alennettu hinta alkaa (pvm).","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Alennettu hinta loppuu (pvm).","type":"string","context":["view","edit"]},"on_sale":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on alennuksessa.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelman voi ostaa.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Jos muunnelma n\u00e4ytet\u00e4\u00e4n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Veron tila.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Veroluokka.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"N\u00e4ytt\u00e4\u00e4 sallitaanko j\u00e4lkitoimitukset.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"N\u00e4ytt\u00e4\u00e4 jos muunnelma on j\u00e4lkitoimituksessa.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","context":["view","edit"]},"dimensions":{"description":"Muunnelman mitat.","type":"object","context":["view","edit"],"properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"Toimitusluokan tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","context":["view","edit"],"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Ominisuuksien lista.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/products\/batch"}]}},"\/wc\/v1\/reports\/sales":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/reports\/sales"}]}},"\/wc\/v1\/reports\/top_sellers":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/reports\/top_sellers"}]}},"\/wc\/v1\/reports":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/reports"}]}},"\/wc\/v1\/taxes\/classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Veroluokan nimi.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/taxes\/classes"}]}},"\/wc\/v1\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"slug":{"description":"Resurssin muista poikkeava polkutunnus.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/taxes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"J\u00e4rjest\u00e4 veroluokan mukaan.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"default":1,"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"default":false,"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"default":true,"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"default":"standard","description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/taxes"}]}},"\/wc\/v1\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/taxes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/taxes\/batch"}]}},"\/wc\/v1\/webhooks":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Rajoita tulosjoukko verkkotoimintokutsuihin joilla on tietty tila.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"default":"active","description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Verkkotoimintokutsun aihe.","required":true},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"delivery_url":{"type":"string","description":"Verkkotoimintokutsun toimitus verkko-osoite.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/webhooks"}]}},"\/wc\/v1\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/webhooks\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v1\/webhooks\/batch"}]}},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Muista poikkeava verkkotoimintokutsun tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Muista poikkeava verkkotoimintokutsun tunniste.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/coupons":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty koodi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":true},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/coupons"}]}},"\/wc\/v2\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/coupons\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/coupons\/batch"}]}},"\/wc\/v2\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/customers":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Rajoita tulosjoukko resursseihin joissa on tietty s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"role":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty rooli.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","wpseo_manager","wpseo_editor","customer","shop_manager"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Uusi k\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","required":true},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Uusi k\u00e4ytt\u00e4j\u00e4nimi.","type":"string","required":false},"password":{"description":"Uusi salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/customers"}]}},"\/wc\/v2\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"reassign":{"default":0,"type":"integer","description":"Tunnus\/ID johon artikkeli kohdistetaan.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/customers\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/customers\/batch"}]}},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Rajoita tulokset asiakkaisiin tai sis\u00e4isiin muistiinpanoihin.","type":"string","enum":["any","customer","internal"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"note":{"type":"string","description":"Tilauksen kommentin sis\u00e4lt\u00f6.","required":true},"customer_note":{"default":false,"description":"Kun tosi, kommentti n\u00e4ytet\u00e4\u00e4n asiakkaille ja heille ilmoitetaan. Jos ep\u00e4tosi, kommentti on vain hallinnon k\u00e4ytett\u00e4viss\u00e4.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"amount":{"description":"Hyvityksen m\u00e4\u00e4r\u00e4.","type":"string","required":false},"reason":{"description":"Hyvityksen syy.","type":"string","required":false},"refunded_by":{"description":"Hyvityksen luoneen k\u00e4ytt\u00e4j\u00e4n tunnus\/ID.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Kun tosi, maksuk\u00e4yt\u00e4v\u00e4n rajapintaa\/API k\u00e4ytet\u00e4\u00e4n hyvityksen tekemisess\u00e4.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/orders":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tilauksiin joilla on tietty tila.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty asiakas.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty tuote.","type":"integer","required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"default":"pending","description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/orders"}]}},"\/wc\/v2\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/orders\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/orders\/batch"}]}},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/attributes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Resurssin nimi.","type":"string","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"default":"select","description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/attributes"}]}},"\/wc\/v2\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/attributes\/batch"}]}},"\/wc\/v2\/products\/categories":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/categories"}]}},"\/wc\/v2\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/categories\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/categories\/batch"}]}},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"review":{"type":"string","description":"Arvion sis\u00e4lt\u00f6.","required":true},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuotearvio luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin arviointi luotiin, GMT aika.","type":["null","string"],"required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"name":{"type":"string","description":"Arvioijan nimi.","required":true},"email":{"type":"string","description":"Arvioijan s\u00e4hk\u00f6postiosoite.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuotearvio luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin arviointi luotiin, GMT aika.","type":["null","string"],"required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"name":{"description":"Arvioijan nimi.","type":"string","required":false},"email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuotearvio luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin arviointi luotiin, GMT aika.","type":["null","string"],"required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"name":{"description":"Arvioijan nimi.","type":"string","required":false},"email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/shipping_classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/shipping_classes"}]}},"\/wc\/v2\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/shipping_classes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/shipping_classes\/batch"}]}},"\/wc\/v2\/products\/tags":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/tags"}]}},"\/wc\/v2\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/tags\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/tags\/batch"}]}},"\/wc\/v2\/products":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Rajoita tuotteiden tulosjoukko varastossa tai loppu varastosta mukaan.","type":"boolean","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"default":"simple","description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"default":"publish","description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"default":true,"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Joukkotuotteiden tunnusten\/ID lista.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Joukkotuotteiden tunnusten\/ID lista.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"description":"Ohitetaanko roskakori ja pakotetaan poisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"T\u00e4ss\u00e4 asetetaan kuinka varastotilanne n\u00e4kyy julkisella puolella. Joko 'Varastossa' tai 'Varasto loppu'.","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Joukkotuotteiden tunnusten\/ID lista.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/products\/batch"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Rajoita tuotteiden tulosjoukko varastossa tai loppu varastosta mukaan.","type":"boolean","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"visible":{"default":true,"description":"M\u00e4\u00e4rit\u00e4 onko muunnelma n\u00e4kyviss\u00e4 tuotesivulla.","type":"boolean","required":false},"virtual":{"default":false,"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta muunnelmien tasolla.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"default":true,"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"visible":{"description":"M\u00e4\u00e4rit\u00e4 onko muunnelma n\u00e4kyviss\u00e4 tuotesivulla.","type":"boolean","required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Muista poikkeava tunniste.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Alennushinnan p\u00e4\u00e4ttymisp\u00e4iv\u00e4 (GMT aikavy\u00f6hyke).","type":["null","string"],"required":false},"visible":{"description":"M\u00e4\u00e4rit\u00e4 onko muunnelma n\u00e4kyviss\u00e4 tuotesivulla.","type":"boolean","required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"in_stock":{"description":"Asettaa kuinka muunnelma esitet\u00e4\u00e4n julkisella puolella; joko \"varastossa\" tai \"loppu varastosta\". ","type":"boolean","required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]},"position":{"description":"Kuvan sijainti. 0 tarkoittaa, ett\u00e4 kuva on artikkelikuva.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/reports\/sales":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/reports\/sales"}]}},"\/wc\/v2\/reports\/top_sellers":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/reports\/top_sellers"}]}},"\/wc\/v2\/reports":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/reports"}]}},"\/wc\/v2\/settings":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/settings"}]}},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/shipping\/zones":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Toimitusvy\u00f6hykkeen nimi.","required":true},"order":{"description":"Toimitusvy\u00f6hykkeiden j\u00e4rjestys.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/shipping\/zones"}]}},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"name":{"description":"Toimitusvy\u00f6hykkeen nimi.","type":"string","required":false},"order":{"description":"Toimitusvy\u00f6hykkeiden j\u00e4rjestys.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"code":{"description":"Toimitusvy\u00f6hyke sijainnin koodi.","type":"string","required":false},"type":{"description":"Toimitusvy\u00f6hyke sijainnin laji.","type":"string","enum":["postcode","state","country","continent"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"order":{"description":"Toimitustavan lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Toimitustavan tila, onko k\u00e4yt\u00f6ss\u00e4.","type":"boolean","required":false},"settings":{"description":"Toimitustavan asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"Toimitustavan tunnus\/ID.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"order":{"description":"Toimitustavan lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Toimitustavan tila, onko k\u00e4yt\u00f6ss\u00e4.","type":"boolean","required":false},"settings":{"description":"Toimitustavan asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/taxes\/classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Veroluokan nimi.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/taxes\/classes"}]}},"\/wc\/v2\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Resurssin muista poikkeava polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Resurssin muista poikkeava polkutunnus.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/taxes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"J\u00e4rjest\u00e4 veroluokan mukaan.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"default":1,"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"default":false,"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"default":true,"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"default":"standard","description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/taxes"}]}},"\/wc\/v2\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/taxes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postinumero.","type":"string","required":false},"city":{"description":"Postitoimipaikan nimi.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/taxes\/batch"}]}},"\/wc\/v2\/webhooks":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Rajoita tulosjoukko verkkotoimintokutsuihin joilla on tietty tila.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"default":"active","description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Verkkotoimintokutsun aihe.","required":true},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"delivery_url":{"type":"string","description":"Verkkotoimintokutsun toimitus verkko-osoite.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/webhooks"}]}},"\/wc\/v2\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/webhooks\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/webhooks\/batch"}]}},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Muista poikkeava verkkotoimintokutsun tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Muista poikkeava verkkotoimintokutsun tunniste.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/system_status":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/system_status"}]}},"\/wc\/v2\/system_status\/tools":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/system_status\/tools"}]}},"\/wc\/v2\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava ty\u00f6kalun tunniste.","type":"string","required":false},"name":{"description":"Ty\u00f6kalun nimi.","type":"string","required":false},"action":{"description":"Mit\u00e4 ty\u00f6kalu tekee.","type":"string","required":false},"description":{"description":"Ty\u00f6kalun kuvaus.","type":"string","required":false},"success":{"description":"Suorittiko ty\u00f6kalu teht\u00e4v\u00e4n?","type":"boolean","required":false},"message":{"description":"Ty\u00f6kalun palauttama viesti.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/shipping_methods":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/shipping_methods"}]}},"\/wc\/v2\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v2\/payment_gateways":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v2\/payment_gateways"}]}},"\/wc\/v2\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"title":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 otsikko kassalla.","type":"string","required":false},"description":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 kuvaus kassalla.","type":"string","required":false},"order":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 k\u00e4yt\u00f6ss\u00e4 tila.","type":"boolean","required":false},"settings":{"description":"Maksuk\u00e4yt\u00e4v\u00e4n asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/coupons":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty koodi.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":true},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/coupons"}]}},"\/wc\/v3\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/coupons\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"Kupongin koodi.","type":"string","required":false},"amount":{"description":"Alennuksen m\u00e4\u00e4r\u00e4. Pit\u00e4\u00e4 aina olla luku, my\u00f6s kun asetetaan prosentti.","type":["number","string"],"required":false},"status":{"description":"Alennuskoodin tila. T\u00e4m\u00e4n tulisi olla joko luonnons, julkaistu tai odottaa tarkistusta","type":"string","required":false},"discount_type":{"description":"M\u00e4\u00e4r\u00e4\u00e4 millaista alennusta k\u00e4ytet\u00e4\u00e4n.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Kupongin kuvaus.","type":"string","required":false},"date_expires":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuponki umpeutuu, GMT aika.","type":["null","string"],"required":false},"individual_use":{"description":"Kun tosi, kuponkia voi k\u00e4ytt\u00e4\u00e4 vain yksin\u00e4\u00e4n. Muut k\u00e4ytetyt kupongit poistetaan ostoskorista.","type":"boolean","required":false},"product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista tuotteiden tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Kuinka monta kertaa yhteens\u00e4 kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"usage_limit_per_user":{"description":"Kuinka monta kertaa sama asiakas voi k\u00e4ytt\u00e4\u00e4 kuponkia.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"Ostoskorissa oleva suurin m\u00e4\u00e4r\u00e4 tuotteita joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"integer","required":false},"free_shipping":{"description":"Kun tosi ja kun maksuton toimitustapa edellytt\u00e4\u00e4 kupongin, t\u00e4m\u00e4 kuponki mahdollistaa maksuttoman toimituksen.","type":"boolean","required":false},"product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista osastojen tunnuksista\/ID joihin kuponkia ei voi k\u00e4ytt\u00e4\u00e4.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Kun tosi, t\u00e4t\u00e4 kuponkia ei k\u00e4ytet\u00e4 tuotteisiin joissa alennettu hinta.","type":"boolean","required":false},"minimum_amount":{"description":"Ostoskorin pienin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"maximum_amount":{"description":"Ostoskorin suurin tilausm\u00e4\u00e4r\u00e4 jolloin kuponkia voi k\u00e4ytt\u00e4\u00e4.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista s\u00e4hk\u00f6postiosoitteista jotka voivat k\u00e4ytt\u00e4\u00e4 t\u00e4t\u00e4 kuponkia.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/coupons\/batch"}]}},"\/wc\/v3\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/customers":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Rajoita tulosjoukko resursseihin joissa on tietty s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"role":{"description":"Rajoita tulosjoukko resursseihin joilla on tietty rooli.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","wpseo_manager","wpseo_editor","customer","shop_manager"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Uusi k\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","required":true},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Uusi k\u00e4ytt\u00e4j\u00e4nimi.","type":"string","required":false},"password":{"description":"Uusi salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/customers"}]}},"\/wc\/v3\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"reassign":{"default":0,"type":"integer","description":"Tunnus\/ID johon artikkeli kohdistetaan.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/customers\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"Asiakkaan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"first_name":{"description":"Asiakkaan etunimi.","type":"string","required":false},"last_name":{"description":"Asiakkaan sukunimi.","type":"string","required":false},"username":{"description":"Asiakkaan kirjautumistunnus.","type":"string","required":false},"password":{"description":"Asiakkaan salasana.","type":"string","required":false},"billing":{"description":"Laskutusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoitteen tietojen lista.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maan ISO-koodi.","type":"string","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/customers\/batch"}]}},"\/wc\/v3\/layout-templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"area":{"description":"Area to get templates for.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/layout-templates"}]}},"\/wc\/v3\/layout-templates\/(?P<id>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Rajoita tulokset asiakkaisiin tai sis\u00e4isiin muistiinpanoihin.","type":"string","enum":["any","customer","internal"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"note":{"type":"string","description":"Tilauksen kommentin sis\u00e4lt\u00f6.","required":true},"customer_note":{"default":false,"description":"Kun tosi, kommentti n\u00e4ytet\u00e4\u00e4n asiakkaille ja heille ilmoitetaan. Jos ep\u00e4tosi, kommentti on vain hallinnon k\u00e4ytett\u00e4viss\u00e4.","type":"boolean","required":false},"added_by_user":{"default":false,"description":"Kun tosi, t\u00e4m\u00e4 kommentti liitet\u00e4\u00e4n nykyiseen k\u00e4ytt\u00e4j\u00e4\u00e4n. Kun ep\u00e4tosi, kommentti liitet\u00e4\u00e4n j\u00e4rjestelm\u00e4\u00e4n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"amount":{"description":"Hyvityksen m\u00e4\u00e4r\u00e4.","type":"string","required":false},"reason":{"description":"Hyvityksen syy.","type":"string","required":false},"refunded_by":{"description":"Hyvityksen luoneen k\u00e4ytt\u00e4j\u00e4n tunnus\/ID.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Kun tosi, maksuk\u00e4yt\u00e4v\u00e4n rajapintaa\/API k\u00e4ytet\u00e4\u00e4n hyvityksen tekemisess\u00e4.","type":"boolean","required":false},"api_restock":{"default":true,"description":"When true, refunded items are restocked.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"Tilauksen tunniste\/ID.","type":"integer","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tilauksiin joilla on tietty tila.","type":"array","items":{"type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty asiakas.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko tilauksiin joissa on tietty tuote.","type":"integer","required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limit result set to orders created via specific sources (e.g. checkout, admin).","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"default":"pending","description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"EUR","description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/orders"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"Ylemm\u00e4n tason tilauksen numero.","type":"integer","required":false},"created_via":{"description":"N\u00e4ytt\u00e4\u00e4 miss\u00e4 tilaus tehtiin.","type":"string","required":false},"status":{"description":"Tilauksen tila.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"ISO muodossa valuutta jolla tilaus on tehty.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"Tilauksen omistajan tunnus\/ID. Vierailijoille 0.","type":"integer","required":false},"customer_note":{"description":"Asiakkaan kassalla j\u00e4tt\u00e4m\u00e4 kommentti.","type":"string","required":false},"billing":{"description":"Laskutusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]},"email":{"description":"S\u00e4hk\u00f6postiosoite.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"Puhelinnumero.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Toimitusosoite.","type":"object","properties":{"first_name":{"description":"Etunimi.","type":"string","context":["view","edit"]},"last_name":{"description":"Sukunimi.","type":"string","context":["view","edit"]},"company":{"description":"Yrityksen nimi.","type":"string","context":["view","edit"]},"address_1":{"description":"Osoiterivi 1","type":"string","context":["view","edit"]},"address_2":{"description":"Osoiterivi 2","type":"string","context":["view","edit"]},"city":{"description":"Postitoimipaikan nimi.","type":"string","context":["view","edit"]},"state":{"description":"L\u00e4\u00e4nin, maakunnan, osavaltion, provinssin tai alueen ISO-koodi tai nimi.","type":"string","context":["view","edit"]},"postcode":{"description":"Postinumero tai -koodi.","type":"string","context":["view","edit"]},"country":{"description":"Maakoodi ISO 3166-1 alpha-2 -muodossa.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"Maksutavan tunnus\/ID","type":"string","required":false},"payment_method_title":{"description":"Maksutavan otsikko.","type":"string","required":false},"transaction_id":{"description":"Muista poikkeava tapahtuman tunnus\/ID.","type":"string","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Tuoterivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Tuotteen nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Parent product name if the product is a variation.","type":"string","context":["view","edit"]},"product_id":{"description":"Tuotteen ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"Muunnelman tunnus\/ID, jos tarvitaan.","type":"integer","context":["view","edit"]},"quantity":{"description":"Tilattu m\u00e4\u00e4r\u00e4.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Tuotteen veroluokka.","type":"string","context":["view","edit"]},"subtotal":{"description":"Rivien v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Rivien verojen v\u00e4lisumma (ennen alennuksia).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"]},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"]},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Meta key for UI display.","type":"string","context":["view","edit"]},"display_value":{"description":"Meta value for UI display.","type":"string","context":["view","edit"]}}}},"sku":{"description":"Tuotetunnus.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Tuotteen hinta.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Properties of the main product image.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Toimitusrivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Toimitustavan nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"Toimitustavan tunnus\/ID.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"Toimitustapahtuman tunnus\/ID.","type":"string","context":["view","edit"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Maksurivien tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Maksun nimi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Maksun veroluokka.","type":"string","context":["view","edit"]},"tax_status":{"description":"Maksun veron tila.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Rivit yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"]},"total_tax":{"description":"Rivien verot yhteens\u00e4 (alennusten j\u00e4lkeen).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Rivin verot.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"Veroprosentin tunnus\/ID","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Verot yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Verojen v\u00e4lisumma.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Kuponkirivin tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotteen tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"Kupongin koodi.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Alennukset yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Alennuksen vero yhteens\u00e4.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Alennustyyppi.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Discount amount as defined in the coupon (absolute value or a percent, depending on the discount type).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Whether the coupon grants free shipping or not.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Meta tiedot.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"M\u00e4\u00e4rit\u00e4 onko tilaus maksettu. Kun se tehd\u00e4\u00e4n, tila asetetaan K\u00e4sittelyss\u00e4 tilaksi ja varaston m\u00e4\u00e4r\u00e4\u00e4 pienennet\u00e4\u00e4n.","type":"boolean","required":false},"manual_update":{"description":"Set the action as manual so that the order note registers as \"added by user\".","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/orders\/batch"}]}},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Muista poikkeava tunnus termien ominaisuudelle.","type":"integer","required":false},"name":{"description":"Termin nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/attributes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Resurssin nimi.","type":"string","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"default":"select","description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"default":"menu_order","description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/attributes"}]}},"\/wc\/v3\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Ominaisuuden nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"type":{"description":"Ominaisuuden laji.","type":"string","enum":["select"],"required":false},"order_by":{"description":"Oletuksena k\u00e4ytett\u00e4v\u00e4 lajittelutapa.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Ota k\u00e4ytt\u00f6\u00f6n\/poista k\u00e4yt\u00f6st\u00e4 ominaisuuksien arkisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/attributes\/batch"}]}},"\/wc\/v3\/products\/categories":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"default":"default","description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/categories"}]}},"\/wc\/v3\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/categories\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Osaston nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason resurssin tunnus\/ID.","type":"integer","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"display":{"description":"Osastojen arkisto, n\u00e4ytt\u00e4misen laji.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys jota k\u00e4ytet\u00e4\u00e4n mukautetussa resurssien j\u00e4rjest\u00e4misess\u00e4.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/categories\/batch"}]}},"\/wc\/v3\/products\/custom-fields\/names":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"order":{"description":"Order sort items ascending or descending.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/custom-fields\/names"}]}},"\/wc\/v3\/products\/reviews":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita vastaus arviointeihin jotka julkaistu ennen annettua p\u00e4iv\u00e4yst\u00e4 ISO8601 muodossa.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Rajoita arviointien tulosjoukko tietyn k\u00e4ytt\u00e4j\u00e4tunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois arvioinnit tietyn k\u00e4ytt\u00e4j\u00e4tunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Rajoita tulosjoukko tietyn kirjoittajan s\u00e4hk\u00f6postin mukaan.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Rajoita arviointien tulosjoukko tietyn tuotetunnuksen\/ID mukaan.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Rajoita arviointien tulosjoukko tietyn tilan mukaan.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste tuotteelle.","type":"integer","required":true},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"default":"approved","description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Arvioijan nimi.","required":true},"reviewer_email":{"type":"string","description":"Arvioijan s\u00e4hk\u00f6postiosoite.","required":true},"review":{"type":"string","description":"Arvion sis\u00e4lt\u00f6.","required":true},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/reviews"}]}},"\/wc\/v3\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"product_id":{"description":"Tuotteen muista poikkeava tunnus jota arviointi koskee.","type":"integer","required":false},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Arvioijan nimi.","type":"string","required":false},"reviewer_email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/reviews\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Tuotteen muista poikkeava tunnus jota arviointi koskee.","type":"integer","required":false},"product_name":{"description":"Tuotteen nimi.","type":"string","required":false},"status":{"description":"Arvioinnin tila.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Arvioijan nimi.","type":"string","required":false},"reviewer_email":{"description":"Arvioijan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"review":{"description":"Arvion sis\u00e4lt\u00f6.","type":"string","required":false},"rating":{"description":"Arvostelu tuotearviosta (0 - 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/reviews\/batch"}]}},"\/wc\/v3\/products\/shipping_classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/shipping_classes"}]}},"\/wc\/v3\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/shipping_classes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/shipping_classes\/batch"}]}},"\/wc\/v3\/products\/shipping_classes\/slug-suggestion":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Toimitusluokan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/shipping_classes\/slug-suggestion"}]}},"\/wc\/v3\/products\/tags":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Offset the result set by a specific number of items. Applies to hierarchical taxonomies only.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma resurssin ominaisuuden perusteella.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko resurssit joita ei ole liitetty mihink\u00e4\u00e4n tuotteeseen.","type":"boolean","default":false,"required":false},"parent":{"description":"Limit result set to resources assigned to a specific parent. Applies to hierarchical taxonomies only.","type":"integer","required":false},"product":{"description":"Rajoita tulosjoukko niihin resursseihin jotka on liitetty tiettyyn tuotteeseen.","type":"integer","default":null,"required":false},"slug":{"description":"Rajoita tulosjoukko niihin resursseihin joilla on tietty polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Resurssin nimi.","required":true},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/tags"}]}},"\/wc\/v3\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/tags\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Avainsanan nimi.","type":"string","required":false},"slug":{"description":"Resurssin kirjaimista ja numeroista koostuva tunniste joka poikkeaa muista saman lajin resursseista.","type":"string","required":false},"description":{"description":"Resurssin HTML-muotoiltu kuvaus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/tags\/batch"}]}},"\/wc\/v3\/products":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limit results to those with a SKU that partial matches a string. This argument takes precedence over 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limit results to those with a name or SKU that partial matches a string. This argument takes precedence over 'search', 'sku' and 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limit search to specific fields when used with search parameter. Available fields: name, sku, global_unique_id, description, short_description. This argument takes precedence over all other search parameters.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limit result set to products with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude products with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limit result set to products with any of the types.","type":"array","items":{"type":"string","enum":["simple","variable"]},"required":false},"exclude_types":{"description":"Exclude products with any of the types from result set.","type":"array","items":{"type":"string","enum":["simple","variable"]},"required":false},"downloadable":{"description":"Limit result set to downloadable products.","type":"boolean","required":false},"virtual":{"description":"Limit result set to virtual products.","type":"boolean","required":false},"pos_products_only":{"description":"Limit result set to products visible in Point of Sale.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"default":"publish","description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"description":"Ohitetaanko roskakori ja pakotetaan poisto.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/batch"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/suggested-products":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Rajoita tulosjoukko tietyn lajisiin tuotteisiin.","type":"string","enum":["simple","variable"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"featured":{"description":"Rajoita tuotteiden tulosjoukko esittelyss\u00e4 olevien mukaan.","type":"boolean","required":false},"category":{"description":"Rajoita tulosjoukko tietyn osaston\/ID tuotteisiin.","type":"string","required":false},"tag":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty avainsana\/ID.","type":"string","required":false},"shipping_class":{"description":"Rajoita tulosjoukko tuotteisiin joilla on tietty toimitusluokka\/ID.","type":"string","required":false},"attribute":{"description":"Rajoita tulokset tuotteisiin joilla tietty ominaisuus. K\u00e4yt\u00e4 luokittelunime\u00e4 tai ominaisuuden polkutunnusta.","type":"string","required":false},"attribute_term":{"description":"Rajoita tulosjoukkot tuotteisiin joilla on tietty ominaisuuden arvo (edellytt\u00e4\u00e4 asetettua ominaisuutta).","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Rajoita tuotteiden tulosjoukko varastossa tai loppu varastosta mukaan.","type":"boolean","required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"categories":{"description":"Limit result set to specific product categorie ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limit result set to specific product tag ids.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limit result set to specific amount of suggested products.","type":"integer","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/products\/suggested-products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Tuotteen nimi.","type":"string","required":false},"slug":{"description":"Tuotteen polkutunnus.","type":"string","required":false},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin tuote luotiin, GMT aika.","type":["null","string"],"required":false},"type":{"description":"Tuotteen laji.","type":"string","enum":["simple","variable"],"required":false},"status":{"description":"Tuotteen tila (julkaisun tila).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Esittelyss\u00e4 oleva tuote.","type":"boolean","required":false},"catalog_visibility":{"description":"Tuoteluettelon n\u00e4kyvyys.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Tuotteen kuvaus.","type":"string","required":false},"short_description":{"description":"Tuotteen lyhyt kuvaus.","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Tuotteen normaali hinta.","type":"string","required":false},"sale_price":{"description":"Tuotteen alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"virtual":{"description":"Jos tuote on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos tuote on ladattava tuote.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"external_url":{"description":"Tuotteen ulkopuolinen verkko-osoite. Vain ulkopuolisille tuotteille.","type":"string","format":"uri","required":false},"button_text":{"description":"Tuotteen ulkopuolisen painikkeen teksti. Vain ulkopuolisille tuotteille.","type":"string","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta tuotetasolla.","type":"boolean","required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the product.","type":["integer","null"],"required":false},"sold_individually":{"description":"Yksi tuote voidaan ostaa yht\u00e4 tilausta kohden.","type":"boolean","required":false},"weight":{"description":"Tuotteen paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Tuotteen mitat.","type":"object","properties":{"length":{"description":"Tuotteen pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Tuotteen leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Tuotteen korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"reviews_allowed":{"description":"Salli tuotearviot.","type":"boolean","required":false},"post_password":{"description":"Artikkelin salasana.","type":"string","required":false},"upsell_ids":{"description":"Lista Parempi tuote (Up-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista Lis\u00e4tuote (Cross-Sell) tuotteiden tunnuksista\/ID.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"Ylemm\u00e4n tason tuotteen tunnus\/ID.","type":"integer","required":false},"purchase_note":{"description":"Valinnainen kommentti joka l\u00e4hetet\u00e4\u00e4n asiakkaalle oston j\u00e4lkeen.","type":"string","required":false},"categories":{"description":"Osatojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Osaston tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Osaston nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Osaston polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista tuotemerkeist\u00e4","type":"array","items":{"type":"object","properties":{"id":{"description":"Tuotemerkin ID.","type":"integer","context":["view","edit"]},"name":{"description":"Tuotemerkin nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Tuotemerkin polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Avainsanojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Avainsanan tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Avainsanan nimi.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Avainsanan polkutunnus.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Kuvien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"position":{"description":"Ominaisuuden sijainti.","type":"integer","context":["view","edit"]},"visible":{"description":"M\u00e4\u00e4rit\u00e4 n\u00e4kyyk\u00f6 ominaisuus \"Lis\u00e4tiedot\" v\u00e4lilehdell\u00e4 tuotteen sivulla.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"M\u00e4\u00e4rit\u00e4, voidaanko ominaisuutta k\u00e4ytt\u00e4\u00e4 muunnelmana.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Ominaisuuden saatavilla olevien (termi)nimien lista.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Muunnelman oletusominaisuudet.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Ominaisuuden polkutunnus."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"id":{"description":"Muista poikkeava tunniste muunnelmalle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Muista poikkeava tunniste muunnelmatuotteelle.","type":"integer","required":false},"delete":{"description":"Poistaa k\u00e4ytt\u00e4m\u00e4tt\u00f6m\u00e4t muunnelmat.","type":"boolean","required":false},"default_values":{"description":"Default values for generated variations.","type":"object","properties":{"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman kuvaus","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Stock Keeping Unit.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN tai ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman tavallinen hinta.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman alennettu hinta.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos muunnelma on palvelu.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos muunnelma on ladattava.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Veroluokka.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Low Stock amount for the variation.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman paino (g (gramma)).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Toimitusluokan polkutunnus.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"variation_quantity_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"]},"group_of_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Require variations to be purchased in multiples of this value.","type":"integer"},"min_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Minimum required variation quantity.","type":"integer"},"max_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Maximum allowed variation quantity.","type":["integer","string"]},"exclude_order_quantity_value_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"]},"exclude_category_quantity_rules":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"]}},"required":false},"description":{"description":"Muunnelman kuvaus","type":"string","required":false},"sku":{"description":"Stock Keeping Unit.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN tai ISBN.","type":"string","required":false},"regular_price":{"description":"Muunnelman tavallinen hinta.","type":"string","required":false},"sale_price":{"description":"Muunnelman alennettu hinta.","type":"string","required":false},"date_on_sale_from":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo alkaa, GMT aika.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"P\u00e4iv\u00e4ys jolloin ale-hinnan voimassaolo p\u00e4\u00e4ttyy, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Muunnelman tila.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Jos muunnelma on palvelu.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Jos muunnelma on ladattava.","type":"boolean","required":false},"downloads":{"description":"Ladattavien tiedostojen lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Tiedoston tunnus\/ID.","type":"string","context":["view","edit"]},"name":{"description":"Tiedoston nimi.","type":"string","context":["view","edit"]},"file":{"description":"Tiedoston verkko-osoite.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"Kuinka monta kertaa ladattavan tiedoston voi ladata ostamisen j\u00e4lkeen.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"Kuinka monen p\u00e4iv\u00e4n kuluttua p\u00e4\u00e4sy ladattaviin tiedostoihin umpeutuu.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Veron tila.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Veroluokka.","type":"string","required":false},"manage_stock":{"default":false,"description":"Varaston hallinta muunnelmien tasolla.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Varaston m\u00e4\u00e4r\u00e4.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Hallitsee tuotteen varastotilannetta.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Jos hallitaan varastoa, t\u00e4ss\u00e4 asetetaan sallitaanko j\u00e4lkitoimitukset.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Low Stock amount for the variation.","type":["integer","null"],"required":false},"weight":{"description":"Muunnelman paino (g (gramma)).","type":"string","required":false},"dimensions":{"description":"Muunnelman mitat.","type":"object","properties":{"length":{"description":"\tMuunnelman pituus (cm (senttimetri)).","type":"string","context":["view","edit"]},"width":{"description":"Muunnelman leveys (cm (senttimetri)).","type":"string","context":["view","edit"]},"height":{"description":"Muunnelman korkeus (cm (senttimetri)).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Toimitusluokan polkutunnus.","type":"string","required":false},"image":{"description":"Muunnelman kuvan tiedot.","type":"object","properties":{"id":{"description":"Kuvan tunnus\/ID.","type":"integer","context":["view","edit"]},"date_created":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuva luotiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, sivuston aikavy\u00f6hykkeell\u00e4.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"P\u00e4iv\u00e4ys jolloin kuvaa viimeksi muokattiin, GMT aika.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"Kuvan verkko-osoite.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Kuvan nimi.","type":"string","context":["view","edit"]},"alt":{"description":"Kuvan vaihtoehtoinen (alt) teksti.","type":"string","context":["view","edit"]}},"required":false},"attributes":{"description":"Ominisuuksien lista.","type":"array","items":{"type":"object","properties":{"id":{"description":"Ominaisuuden tunnus\/ID.","type":"integer","context":["view","edit"]},"name":{"description":"Ominaisuuden nimi.","type":"string","context":["view","edit"]},"option":{"description":"Valittu ominaisuus termin nimi.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Valikkojen j\u00e4rjestys, k\u00e4ytet\u00e4\u00e4n tuotteiden mukautettuun j\u00e4rjest\u00e4miseen.","type":"integer","required":false},"meta_data":{"description":"Meta tiedot.","type":"array","items":{"type":"object","properties":{"id":{"description":"Meta tunnus\/ID.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Meta-avain.","type":"string","context":["view","edit"]},"value":{"description":"Meta-arvo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"variation_quantity_rules":{"description":"Enable this option to set quantity rules for a specific variation.","type":"string","enum":["yes","no"],"required":false},"group_of_quantity":{"description":"Require variations to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required variation quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed variation quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude variation from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude variation from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/refunds":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"Desimaalien m\u00e4\u00e4r\u00e4 jota k\u00e4ytet\u00e4\u00e4n resursseissa.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Only show meta which is meant to be displayed for an order.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/refunds"}]}},"\/wc\/v3\/reports\/sales":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/sales"}]}},"\/wc\/v3\/reports\/top_sellers":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Raportin ajanjakso.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Palauttaa myynnit tietylle aloitus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"date_max":{"description":"Palauttaa myynnit tietylle lopetus p\u00e4iv\u00e4lle, p\u00e4iv\u00e4yksen on oltava YYYY-MM-DD muodossa.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/top_sellers"}]}},"\/wc\/v3\/reports\/orders\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/orders\/totals"}]}},"\/wc\/v3\/reports\/products\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/products\/totals"}]}},"\/wc\/v3\/reports\/customers\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/customers\/totals"}]}},"\/wc\/v3\/reports\/coupons\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/coupons\/totals"}]}},"\/wc\/v3\/reports\/reviews\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports\/reviews\/totals"}]}},"\/wc\/v3\/reports":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/reports"}]}},"\/wc\/v3\/settings":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/settings"}]}},"\/wc\/v3\/settings\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/settings\/batch"}]}},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"Asetusten ryhm\u00e4tunnus\/ID.","type":"string","required":false},"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"value":{"description":"Asetuksen arvo.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/shipping\/zones":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Toimitusvy\u00f6hykkeen nimi.","required":true},"order":{"description":"Toimitusvy\u00f6hykkeiden j\u00e4rjestys.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/shipping\/zones"}]}},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"name":{"description":"Toimitusvy\u00f6hykkeen nimi.","type":"string","required":false},"order":{"description":"Toimitusvy\u00f6hykkeiden j\u00e4rjestys.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava tunnus\/ID resurssille.","type":"integer","required":false},"code":{"description":"Toimitusvy\u00f6hyke sijainnin koodi.","type":"string","required":false},"type":{"description":"Toimitusvy\u00f6hyke sijainnin laji.","type":"string","enum":["postcode","state","country","continent"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"order":{"description":"Toimitustavan lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Toimitustavan tila, onko k\u00e4yt\u00f6ss\u00e4.","type":"boolean","required":false},"settings":{"description":"Toimitustavan asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"Toimitustavan tunnus\/ID.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"order":{"description":"Toimitustavan lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Toimitustavan tila, onko k\u00e4yt\u00f6ss\u00e4.","type":"boolean","required":false},"settings":{"description":"Toimitustavan asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"Muista poikkeava tunnus\/ID vy\u00f6hykkeelle.","type":"integer","required":false},"instance_id":{"description":"Muista poikkeava tunnus\/ID tapaukselle.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Ohitetaanko roskakori ja pakotetaan poisto.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/taxes\/classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Veroluokan nimi.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/taxes\/classes"}]}},"\/wc\/v3\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Resurssin muista poikkeava polkutunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Resurssin muista poikkeava polkutunnus.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/taxes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"J\u00e4rjest\u00e4 veroluokan mukaan.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"default":1,"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"default":false,"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"default":true,"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"default":"standard","description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/taxes"}]}},"\/wc\/v3\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/taxes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"ISO 3166 -muotoinen maatunnus.","type":"string","required":false},"state":{"description":"L\u00e4\u00e4nin\/maakunnan koodi.","type":"string","required":false},"postcode":{"description":"Postcode\/ZIP, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'postcodes' should be used instead.","type":"string","required":false},"city":{"description":"City name, it doesn't support multiple values. Deprecated as of WooCommerce 5.3, 'cities' should be used instead.","type":"string","required":false},"rate":{"description":"Veroprosentti.","type":"string","required":false},"name":{"description":"Veroprosentin nimi.","type":"string","required":false},"priority":{"description":"Veron j\u00e4rjestys\/sijoitus..","type":"integer","required":false},"compound":{"description":"Onko t\u00e4m\u00e4 yhdistelm\u00e4veroprosentti.","type":"boolean","required":false},"shipping":{"description":"K\u00e4ytet\u00e4\u00e4nk\u00f6 t\u00e4t\u00e4 veroprosenttia my\u00f6s toimitukseen.","type":"boolean","required":false},"order":{"description":"Ilmaisee kutsuissa ilmenev\u00e4n j\u00e4rjestyksen.","type":"integer","required":false},"class":{"description":"Veroluokka.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista postinumeroista. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista kaupunkien nimist\u00e4. Esitelty WooCommerce 5.3:ssa.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/taxes\/batch"}]}},"\/wc\/v3\/variations":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Nykyinen sivu kokoelmassa.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Tulosten joukossa palautettavien tuotteiden suurin m\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajoita tulokset niihin jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon.","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limit response to resources modified after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limit response to resources modified before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Whether to consider GMT post dates when limiting response by published or modified date.","type":"boolean","default":false,"required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Rajoita tulosjoukko niihin joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajoita tulosjoukko kaikkiin tuotteisiin poislukien ne joilla on tietty ylemm\u00e4n tason tunnus\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Rajoita tulosjoukko niihin tuotteisiin joilla on tietty polkutunnus.","type":"string","required":false},"status":{"default":"any","description":"Rajoita tulosjoukko tuotteisiin joilla on tietty tila.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Rajaa tulosjoukko tuotteisiin joilla tietty tuotetunnus (SKU). Jos useita, erota pilkulla.","type":"string","required":false},"tax_class":{"description":"Rajoita tuotteiden tulosjoukko tietyn veroluokan mukaan.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Rajoita tuotteiden tulosjoukko alennuksessa olevien mukaan.","type":"boolean","required":false},"min_price":{"description":"Rajoita tuotteiden tulosjoukko alimman hinnan mukaan.","type":"string","required":false},"max_price":{"description":"Rajoita tuotteiden tulosjoukko korkeimman hinnan mukaan.","type":"string","required":false},"include_meta":{"default":[],"description":"Limit meta_data to specific keys.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Ensure meta_data excludes specific keys.","type":"array","items":{"type":"string"},"required":false},"stock_status":{"description":"Rajoita tuotteiden tulosjoukko tietyn varastotilanteen mukaan.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limit result set to products with or without price.","type":"boolean","required":false},"attributes":{"description":"Limit result set to products with specified attributes.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Ominaisuuden polkutunnus."},"term":{"type":"string","description":"Attribute term."},"terms":{"type":"array","description":"Attribute terms."}}},"required":false},"virtual":{"description":"Limit result set to virtual product variations.","type":"boolean","required":false},"downloadable":{"description":"Limit result set to downloadable product variations.","type":"boolean","required":false},"include_status":{"description":"Limit result set to product variations with any of the statuses.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Exclude product variations with any of the statuses from result set.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limit result set to variations visible in Point of Sale.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/variations"}]}},"\/wc\/v3\/webhooks":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ISO8601-muotoa noudattavan p\u00e4iv\u00e4ksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset resursseihin jotka on julkaistu ennen ISO8601-muotoilua noudattavaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista ett\u00e4 tulosjoukosta rajattu pois tietyt tunnukset\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajoita tulosjoukko tiettyihin tunnuksiin\/ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Siirr\u00e4 tulosjoukon alkua tietty lukum\u00e4\u00e4r\u00e4.","type":"integer","required":false},"order":{"description":"J\u00e4rjestyksen ominaisuus joko nouseva tai laskeva.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Rajoita tulosjoukko verkkotoimintokutsuihin joilla on tietty tila.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"default":"active","description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Verkkotoimintokutsun aihe.","required":true},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"delivery_url":{"type":"string","description":"Verkkotoimintokutsun toimitus verkko-osoite.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/webhooks"}]}},"\/wc\/v3\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"On oltava tosi, koska resurssi ei tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/webhooks\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Helposti muistettava nimi verkkotoimintokutsulle.","type":"string","required":false},"status":{"description":"Verkkotoimintokutsun tila.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Verkkotoimintokutsun aihe.","type":"string","required":false},"secret":{"description":"Salainen avain jota k\u00e4ytetty toimitetun verkkotoimintokutsun salausavaimen luomisessa ja joka on pyynn\u00f6n headereissa. Oletuksena on MD5-salausavain joka on tehty k\u00e4ytt\u00e4j\u00e4n tunnuksesta (ID) | k\u00e4ytt\u00e4j\u00e4tunnus jos muuten ei ole asetettu.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/webhooks\/batch"}]}},"\/wc\/v3\/system_status":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/system_status"}]}},"\/wc\/v3\/system_status\/tools":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/system_status\/tools"}]}},"\/wc\/v3\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava ty\u00f6kalun tunniste.","type":"string","required":false},"name":{"description":"Ty\u00f6kalun nimi.","type":"string","required":false},"action":{"description":"Mit\u00e4 ty\u00f6kalu tekee.","type":"string","required":false},"description":{"description":"Ty\u00f6kalun kuvaus.","type":"string","required":false},"success":{"description":"Suorittiko ty\u00f6kalu teht\u00e4v\u00e4n?","type":"boolean","required":false},"message":{"description":"Ty\u00f6kalun palauttama viesti.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/shipping_methods":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/shipping_methods"}]}},"\/wc\/v3\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/payment_gateways":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/payment_gateways"}]}},"\/wc\/v3\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Muista poikkeava resurssin tunniste.","type":"string","required":false},"title":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 otsikko kassalla.","type":"string","required":false},"description":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 kuvaus kassalla.","type":"string","required":false},"order":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 lajitteluj\u00e4rjestys.","type":"integer","required":false},"enabled":{"description":"Maksuk\u00e4yt\u00e4v\u00e4 k\u00e4yt\u00f6ss\u00e4 tila.","type":"boolean","required":false},"settings":{"description":"Maksuk\u00e4yt\u00e4v\u00e4n asetukset.","type":"object","properties":{"id":{"description":"Muista poikkeava tunniste asetukselle.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Asetuksen selkokielinen tunnus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Asetuksen selkokielinen kuvaus jota k\u00e4ytet\u00e4\u00e4n k\u00e4ytt\u00f6liittymiss\u00e4.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Asetuksen laji.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Asetuksen arvo.","type":"string","context":["view","edit"]},"default":{"description":"Asetuksen oletusarvo.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Asetuksesta k\u00e4ytt\u00e4j\u00e4lle n\u00e4ytett\u00e4v\u00e4n lis\u00e4ohjeen teksti.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Paikanvaraus teksti joka n\u00e4ytet\u00e4\u00e4n tekstilaatikoissa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/data":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/data"}]}},"\/wc\/v3\/data\/continents":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/data\/continents"}]}},"\/wc\/v3\/data\/continents\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"continent":{"description":"2-merkin mannertunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/data\/countries":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/data\/countries"}]}},"\/wc\/v3\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO3166 alpha-2 maatunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/data\/currencies":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/data\/currencies"}]}},"\/wc\/v3\/data\/currencies\/current":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/data\/currencies\/current"}]}},"\/wc\/v3\/data\/currencies\/(?P<currency>[\\w-]{3})":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"ISO4217 mukainen valuutan tunnus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/paypal-standard\/update-shipping":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/paypal-standard\/update-shipping"}]}},"\/wc\/v3\/paypal-webhooks":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/paypal-webhooks"}]}},"\/wc\/v3\/paypal-buttons\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/paypal-buttons\/create-order"}]}},"\/wc\/v3\/paypal-buttons\/cancel-payment":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/paypal-buttons\/cancel-payment"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/receipt":{"namespace":"wc\/v3","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Tilauksen yksil\u00f6llinen tunnus.","type":"integer","required":false},"expiration_date":{"description":"Viimeinen voimassaolop\u00e4iv\u00e4 muodossa yyyy-mm-dd.","type":"string","default":null,"required":false},"expiration_days":{"description":"P\u00e4ivien m\u00e4\u00e4r\u00e4, joka lis\u00e4t\u00e4\u00e4n nykyiseen p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4n, jotta saadaan viimeinen voimassaolop\u00e4iv\u00e4.","type":"integer","default":1,"required":false},"force_new":{"description":"Valittuna pakottaa uuden kuitin luomisen vaikka kuitti olisi jo olemassa eik\u00e4 ole viel\u00e4 er\u00e4\u00e4ntynyt.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"id":{"description":"Tilauksen yksil\u00f6llinen tunnus.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/email_templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Tilauksen yksil\u00f6llinen tunnus.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_email":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Tilauksen yksil\u00f6llinen tunnus.","type":"integer","required":false},"email":{"description":"Email address to send the order details to.","type":"string","format":"email","required":false},"force_email_update":{"description":"P\u00e4ivitet\u00e4\u00e4nk\u00f6 tilauksen laskutusosoitteen s\u00e4hk\u00f6posti, vaikka sill\u00e4 olisi jo sellainen.","type":"boolean","required":false},"template_id":{"description":"S\u00e4hk\u00f6postin l\u00e4hett\u00e4miseen k\u00e4ytett\u00e4v\u00e4n mallipohjan ID.","type":"string","enum":["new_order","cancelled_order","customer_cancelled_order","failed_order","customer_failed_order","customer_on_hold_order","customer_processing_order","customer_completed_order","customer_refunded_order","customer_invoice","customer_note","customer_reset_password","customer_new_account","customer_pos_completed_order","customer_pos_refunded_order","subscription_code_email","order_completed_custom_email","failed_renewal_authentication","failed_preorder_sca_authentication","failed_authentication_requested","wc_stripe_failed_refund_admin","wc_stripe_failed_refund_customer"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_order_details":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Tilauksen yksil\u00f6llinen tunnus.","type":"integer","required":false},"email":{"description":"Email address to send the order details to.","type":"string","format":"email","required":false},"force_email_update":{"description":"P\u00e4ivitet\u00e4\u00e4nk\u00f6 tilauksen laskutusosoitteen s\u00e4hk\u00f6posti, vaikka sill\u00e4 olisi jo sellainen.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc\/v3\/orders\/statuses":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc\/v3\/orders\/statuses"}]}},"\/wc-admin\/settings\/payments\/country":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"location":{"description":"The ISO3166 alpha-2 country code to save for the current user.","type":"string","pattern":"[a-zA-Z]{2}","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/country"}]}},"\/wc-admin\/settings\/payments\/providers":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to WooCommerce&#039;s base location country.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/providers"}]}},"\/wc-admin\/settings\/payments\/providers\/order":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"order_map":{"description":"A map of provider ID to integer values representing the sort order.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/providers\/order"}]}},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/attach":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<suggestion_id>[\\w\\d\\-]+)\/incentive\/(?P<incentive_id>[\\w\\d\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"The context ID for which to dismiss the incentive. If not provided, will dismiss the incentive for all contexts.","type":"string","required":false},"do_not_track":{"description":"If true, the incentive dismissal will be ignored by tracking.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/start":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/save":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/check":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/clean":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"ISO3166 alpha-2 country code. Defaults to the stored providers business location country code.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Where from in the onboarding flow this request was triggered.","type":"string","required":false},"source":{"description":"The upmost entry point from where the merchant entered the onboarding flow.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable"}]}},"\/wc-admin-email":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin-email","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin-email"}]}},"\/wc-admin-email\/settings\/email\/send-preview":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"The email type to preview.","type":"string","required":true},"email":{"description":"Email address to send the email preview to.","type":"string","format":"email","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin-email\/settings\/email\/send-preview"}]}},"\/wc-admin-email\/settings\/email\/preview-subject":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"The email type to get subject for.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin-email\/settings\/email\/preview-subject"}]}},"\/wc-admin-email\/settings\/email\/save-transient":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","description":"The key for the transient. Must be one of the allowed options.","required":true},"value":{"type":"string","description":"The value to be saved for the transient.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin-email\/settings\/email\/save-transient"}]}},"\/wc-admin-email\/settings\/email\/listing\/recreate-email-post":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email_id":{"description":"The email ID to recreate the post for.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-admin-email\/settings\/email\/listing\/recreate-email-post"}]}},"\/wc-telemetry":{"namespace":"wc-telemetry","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-telemetry","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-telemetry"}]}},"\/wc-telemetry\/tracker":{"namespace":"wc-telemetry","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"platform":{"description":"Platform to track.","type":"string","required":true},"version":{"description":"Platform version to track.","type":"string","required":true},"installation_date":{"description":"WooCommerce-mobiilisovelluksen asennusp\u00e4iv\u00e4m\u00e4\u00e4r\u00e4.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wc-telemetry\/tracker"}]}},"\/wccom-site\/v3":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wccom-site\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3"}]}},"\/wccom-site\/v3\/installer\/(?P<product_id>\\d+)\/state":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wccom-site\/v3\/installer":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"run-until-step":{"type":"string","enum":["get_product_info","download_product","unpack_product","move_product","activate_product"],"required":true},"idempotency-key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/installer"}]}},"\/wccom-site\/v3\/installer\/reset":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"idempotency-key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/installer\/reset"}]}},"\/wccom-site\/v3\/ssr":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/ssr"}]}},"\/wccom-site\/v3\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/status"}]}},"\/wccom-site\/v3\/connection\/disconnect":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/connection\/disconnect"}]}},"\/wccom-site\/v3\/connection\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wccom-site\/v3\/connection\/status"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Kyvykkyyskategorian yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"slug":{"description":"Kyvykkyyskategorian yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Kyvykkyyden yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Kyvykkyyden suorituksen sy\u00f6tt\u00f6parametrit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Kyvykkyyden yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Kyvykkyyden suorituksen sy\u00f6tt\u00f6parametrit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Rajoita tulokset tietyn kykykategorian kykyihin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Rajoita tulokset tietyn kykykategorian kykyihin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Kyvykkyyden yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["GET"],"args":{"name":{"description":"Kyvykkyyden yksil\u00f6iv\u00e4 tunniste.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/jetpack\/v4\/verify_registration":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/verify_registration"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Set to false will trigger the site to disconnect.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indicates where the registration action was triggered for tracking\/segmentation purposes","type":"string","required":false},"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false},"plugin_slug":{"description":"Indicates from what plugin the request is coming from","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI of the admin page where the user should be redirected after connection flow","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"New user token","type":"string","required":true},"is_connection_owner":{"description":"Is connection owner","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"New owner","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"author":{"description":"Rajaa tulokset tiettyjen kirjoittajien artikkeleihin. ","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Varmistaa ettei tuloksissa ole artikkeleita, jotka on liitetty tiettyihin kirjoittajiin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan categories.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa categories.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan tags.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa tags.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Rajaa tulokset kiinnitettyihin kohteisiin. ","type":"boolean","required":false},"ignore_sticky":{"description":"Ohitetaanko kiinnitetyt julkaisut vai ei.","type":"boolean","default":true,"required":false},"format":{"description":"Rajoita tulosjoukko kohteiksi, joille on m\u00e4\u00e4ritetty yksi tai useampi valittu muoto.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Artikkelin muoto.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Onko artikkeli kiinnitetty. ","type":"boolean","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"categories":{"description":"Artikkeliin liitetyt termit luokittelussa category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Artikkeliin liitetyt termit luokittelussa post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Yliaja otteen oletuspituus.","type":"integer","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Artikkelin muoto.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Onko artikkeli kiinnitetty. ","type":"boolean","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"categories":{"description":"Artikkeliin liitetyt termit luokittelussa category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Artikkeliin liitetyt termit luokittelussa post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Artikkelin muoto.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Onko artikkeli kiinnitetty. ","type":"boolean","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"categories":{"description":"Artikkeliin liitetyt termit luokittelussa category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Artikkeliin liitetyt termit luokittelussa post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"author":{"description":"Rajaa tulokset tiettyjen kirjoittajien artikkeleihin. ","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Varmistaa ettei tuloksissa ole artikkeleita, jotka on liitetty tiettyihin kirjoittajiin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Rajaa tulokset tiettyyn menu_order-arvoon.","type":"integer","required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Rajaa tulokset kohteisiin, joiden vanhemmalla on jokin m\u00e4\u00e4ritellyist\u00e4 id:ist\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajaa tulokset kohteisiin, joiden vanhemmalla ei ole tietty\u00e4 id:t\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n kohteen ID.","type":"integer","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Artikkelin j\u00e4rjestys suhteessa muihin artikkeleihin.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Yliaja otteen oletuspituus.","type":"integer","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n kohteen ID.","type":"integer","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Artikkelin j\u00e4rjestys suhteessa muihin artikkeleihin.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n kohteen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Artikkelin j\u00e4rjestys suhteessa muihin artikkeleihin.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"author":{"description":"Rajaa tulokset tiettyjen kirjoittajien artikkeleihin. ","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Varmistaa ettei tuloksissa ole artikkeleita, jotka on liitetty tiettyihin kirjoittajiin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Rajaa tulokset kohteisiin, joiden vanhemmalla on jokin m\u00e4\u00e4ritellyist\u00e4 id:ist\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Rajaa tulokset kohteisiin, joiden vanhemmalla ei ole tietty\u00e4 id:t\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Rajoita tulosjoukko tietyn mediatyypin tai mediatyyppien liitteisiin.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Rajoita tulosjoukko tiettyyn MIME-tyypiin tai tiettyihin MIME-tyyppeihin.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"alt_text":{"description":"Vaihtoehtoinen teksti n\u00e4ytett\u00e4v\u00e4ksi kun liitett\u00e4 ei voida n\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"caption":{"description":"Liitetiedoston kuvateksti.","type":"object","properties":{"raw":{"description":"Liitteen kuvateksti, sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Liitetiedoston kuvaus.","type":"object","properties":{"raw":{"description":"Liitteen kuvaus sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Mediaan liittyv\u00e4n artikkelin ID.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Artikkelin kirjoittajan ID.","type":"integer","required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"comment_status":{"description":"Onko artikkelin kommentointi k\u00e4yt\u00f6ss\u00e4. ","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Voiko artikkelille tehd\u00e4 paluuviitteen.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"alt_text":{"description":"Vaihtoehtoinen teksti n\u00e4ytett\u00e4v\u00e4ksi kun liitett\u00e4 ei voida n\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"caption":{"description":"Liitetiedoston kuvateksti.","type":"object","properties":{"raw":{"description":"Liitteen kuvateksti, sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Liitetiedoston kuvaus.","type":"object","properties":{"raw":{"description":"Liitteen kuvaus sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Mediaan liittyv\u00e4n artikkelin ID.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Liitteen uniikki tunniste.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"Muokatun kuvan URL-osoite.","type":"string","format":"uri","required":true},"modifiers":{"description":"Kuvanmuokkausten taulukko.","type":"array","minItems":1,"items":{"description":"Kuvan muokkaus.","type":"object","required":["type","args"],"oneOf":[{"title":"K\u00e4\u00e4nn\u00e4","properties":{"type":{"description":"K\u00e4\u00e4nt\u00e4misen tyyppi.","type":"string","enum":["flip"]},"args":{"description":"K\u00e4\u00e4nt\u00e4misen argumentit.","type":"object","required":["flip"],"properties":{"flip":{"description":"K\u00e4\u00e4nt\u00f6suunta.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"K\u00e4\u00e4nnet\u00e4\u00e4nk\u00f6 vaakasuunnassa.","type":"boolean"},"vertical":{"description":"K\u00e4\u00e4nnet\u00e4\u00e4nk\u00f6 pystysuunnassa.","type":"boolean"}}}}}}},{"title":"Kierto","properties":{"type":{"description":"Kiertotapa.","type":"string","enum":["rotate"]},"args":{"description":"Kierron argumentit.","type":"object","required":["angle"],"properties":{"angle":{"description":"Kiertokulma my\u00f6t\u00e4p\u00e4iv\u00e4\u00e4n asteissa.","type":"number"}}}}},{"title":"Rajaa","properties":{"type":{"description":"Rajaustapa.","type":"string","enum":["crop"]},"args":{"description":"Rajausargumentit.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horisontaalinen vasemmanpuoleinen positio, josta kuvan rajaus alkaa prosenttiosuutena kuvan leveydest\u00e4.","type":"number"},"top":{"description":"Vertikaalinen yl\u00e4positio, josta kuvan rajaus alkaa prosenttiosuutena kuvan korkeudesta.","type":"number"},"width":{"description":"Rajauksen leveys prosenttiosuutena kuvan leveydest\u00e4.","type":"number"},"height":{"description":"Rajauksen korkeus prosenttiosuutena kuvan korkeudesta.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Asteiden m\u00e4\u00e4r\u00e4, jolla kuvaa k\u00e4\u00e4nnet\u00e4\u00e4n my\u00f6t\u00e4p\u00e4iv\u00e4\u00e4n. VANHENTUNUT: K\u00e4yt\u00e4 \"modifiers\":ia sen sijasta.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Prosenttiosuutena kuvasta. X-asema, josta rajaus alkaa. VANHENTUNUT: K\u00e4yt\u00e4 \"modifiers\":ia sen sijasta.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Prosenttiosuutena kuvasta. Y-positio, josta rajaus alkaa. VANHENTUNUT: K\u00e4yt\u00e4 \"modifiers\":ia sen sijasta.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Prosenttiosuutena kuvasta. Leveys, johon kuva rajataan. VANHENTUNUT: K\u00e4yt\u00e4 \"modifiers\":ia sen sijasta.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Prosenttiosuutena kuvasta. Korkeus, johon kuva rajataan. VANHENTUNUT: K\u00e4yt\u00e4 \"modifiers\":ia sen sijasta.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Liitetiedoston kuvateksti.","type":"object","properties":{"raw":{"description":"Liitteen kuvateksti, sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Liitetiedoston kuvaus.","type":"object","properties":{"raw":{"description":"Liitteen kuvaus sellaisena kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Liitteen HTML-muotoinen kuvaus sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Mediaan liittyv\u00e4n artikkelin ID.","type":"integer","required":false},"alt_text":{"description":"Vaihtoehtoinen teksti n\u00e4ytett\u00e4v\u00e4ksi kun liitett\u00e4 ei voida n\u00e4ytt\u00e4\u00e4.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan menus.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa menus.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Rajaa tulokset tiettyyn menu_order-arvoon.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Kohteen otsikko. ","type":["string","object"],"properties":{"raw":{"description":"Kohteen otsikko siten, kuin se esiintyy tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Kohteen HTML-muotoinen otsikko, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Alkuper\u00e4isen kohteen tyyppi kuten \"post_type\" tai \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Kohteen nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"default":0,"description":"Kohteen vanhemman tunniste.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"T\u00e4m\u00e4n valikkokohteen title-attribuutin teksti.","type":"string","required":false},"classes":{"description":"T\u00e4m\u00e4n valikkokohteen linkin luokkien nimet.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"T\u00e4m\u00e4n valikkokohteen kuvaus.","type":"string","required":false},"menu_order":{"default":1,"description":"Tietokannan ID nav_menu_item-kohteelle, joka on t\u00e4m\u00e4n ylempi valikkokohde, jos sellainen on l\u00f6ytyy. Muussa tapauksessa 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Alkuper\u00e4isen esitetyn kohteen tyyppi kuten \"category\", \"post\", tai \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"Tietokannan ID alkuper\u00e4iseen kohteeseen, jota t\u00e4m\u00e4 valikkokohde esitt\u00e4\u00e4 kuten ID artikkeleille tai term_id kategorioille.","type":"integer","minimum":0,"required":false},"target":{"description":"T\u00e4m\u00e4n valikkokohteen linkin kohde.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL, johon valikkokohde viittaa.","type":"string","format":"uri","required":false},"xfn":{"description":"T\u00e4ss\u00e4 valikkokohteen linkiss\u00e4 esitetty XFN-suhde.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Kohteeseen liitetyt termit taksonomiassa nav_menu.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"title":{"description":"Kohteen otsikko. ","type":["string","object"],"properties":{"raw":{"description":"Kohteen otsikko siten, kuin se esiintyy tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Kohteen HTML-muotoinen otsikko, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Alkuper\u00e4isen kohteen tyyppi kuten \"post_type\" tai \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Kohteen nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"parent":{"description":"Kohteen vanhemman tunniste.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"T\u00e4m\u00e4n valikkokohteen title-attribuutin teksti.","type":"string","required":false},"classes":{"description":"T\u00e4m\u00e4n valikkokohteen linkin luokkien nimet.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"T\u00e4m\u00e4n valikkokohteen kuvaus.","type":"string","required":false},"menu_order":{"description":"Tietokannan ID nav_menu_item-kohteelle, joka on t\u00e4m\u00e4n ylempi valikkokohde, jos sellainen on l\u00f6ytyy. Muussa tapauksessa 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Alkuper\u00e4isen esitetyn kohteen tyyppi kuten \"category\", \"post\", tai \"attachment\".","type":"string","required":false},"object_id":{"description":"Tietokannan ID alkuper\u00e4iseen kohteeseen, jota t\u00e4m\u00e4 valikkokohde esitt\u00e4\u00e4 kuten ID artikkeleille tai term_id kategorioille.","type":"integer","minimum":0,"required":false},"target":{"description":"T\u00e4m\u00e4n valikkokohteen linkin kohde.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL, johon valikkokohde viittaa.","type":"string","format":"uri","required":false},"xfn":{"description":"T\u00e4ss\u00e4 valikkokohteen linkiss\u00e4 esitetty XFN-suhde.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Kohteeseen liitetyt termit taksonomiassa nav_menu.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Kohteen vanhemman tunniste.","type":"integer","minimum":0,"required":false},"title":{"description":"Kohteen otsikko. ","type":["string","object"],"properties":{"raw":{"description":"Kohteen otsikko siten, kuin se esiintyy tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Kohteen HTML-muotoinen otsikko, sellaisena kuin se tulostetaan selaimelle.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Alkuper\u00e4isen kohteen tyyppi kuten \"post_type\" tai \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Kohteen nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"attr_title":{"description":"T\u00e4m\u00e4n valikkokohteen title-attribuutin teksti.","type":"string","required":false},"classes":{"description":"T\u00e4m\u00e4n valikkokohteen linkin luokkien nimet.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"T\u00e4m\u00e4n valikkokohteen kuvaus.","type":"string","required":false},"menu_order":{"description":"Tietokannan ID nav_menu_item-kohteelle, joka on t\u00e4m\u00e4n ylempi valikkokohde, jos sellainen on l\u00f6ytyy. Muussa tapauksessa 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Alkuper\u00e4isen esitetyn kohteen tyyppi kuten \"category\", \"post\", tai \"attachment\".","type":"string","required":false},"object_id":{"description":"Tietokannan ID alkuper\u00e4iseen kohteeseen, jota t\u00e4m\u00e4 valikkokohde esitt\u00e4\u00e4 kuten ID artikkeleille tai term_id kategorioille.","type":"integer","minimum":0,"required":false},"target":{"description":"T\u00e4m\u00e4n valikkokohteen linkin kohde.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL, johon valikkokohde viittaa.","type":"string","format":"uri","required":false},"xfn":{"description":"T\u00e4ss\u00e4 valikkokohteen linkiss\u00e4 esitetty XFN-suhde.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Kohteeseen liitetyt termit taksonomiassa nav_menu.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wp_pattern_category":{"description":"Artikkeliin liitetyt termit luokittelussa wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Yliaja otteen oletuspituus.","type":"integer","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wp_pattern_category":{"description":"Artikkeliin liitetyt termit luokittelussa wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wp_pattern_category":{"description":"Artikkeliin liitetyt termit luokittelussa wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Rajaa tiettyyn artikkelin tunnisteeseen (ID).","type":"integer","required":false},"area":{"description":"Rajoita tiettyyn sivupohjan osien alueeseen.","type":"string","required":false},"post_type":{"description":"Sis\u00e4lt\u00f6tyyppi, jolle haetaan sivupohjia.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"default":"","description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"default":"publish","description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Sivupohjan tunnus, jota k\u00e4ytet\u00e4\u00e4n varavaihtoehtona","type":"string","required":true},"is_custom":{"description":"Osoittaa onko sivupohja mukautettu vai osa sivupohjien hierarkiaa","type":"boolean","required":false},"template_prefix":{"description":"Sivupohjan etuliite luodulle sivupohjalle. T\u00e4t\u00e4 k\u00e4ytet\u00e4\u00e4n sivupohjan p\u00e4\u00e4tyypin erottamiseen kuten `taxonomy-books` erottaa tyypin `taxonomy`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"area":{"description":"Miss\u00e4 sivupohjan osaa on tarkoitettu k\u00e4ytett\u00e4v\u00e4n (yl\u00e4- ja alatunniste, jne.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Sivupohjan ID","type":"string","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Rajaa tiettyyn artikkelin tunnisteeseen (ID).","type":"integer","required":false},"area":{"description":"Rajoita tiettyyn sivupohjan osien alueeseen.","type":"string","required":false},"post_type":{"description":"Sis\u00e4lt\u00f6tyyppi, jolle haetaan sivupohjia.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"default":"","description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"default":"publish","description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"area":{"description":"Miss\u00e4 sivupohjan osaa on tarkoitettu k\u00e4ytett\u00e4v\u00e4n (yl\u00e4- ja alatunniste, jne.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Sivupohjan tunnus, jota k\u00e4ytet\u00e4\u00e4n varavaihtoehtona","type":"string","required":true},"is_custom":{"description":"Osoittaa onko sivupohja mukautettu vai osa sivupohjien hierarkiaa","type":"boolean","required":false},"template_prefix":{"description":"Sivupohjan etuliite luodulle sivupohjalle. T\u00e4t\u00e4 k\u00e4ytet\u00e4\u00e4n sivupohjan p\u00e4\u00e4tyypin erottamiseen kuten `taxonomy-books` erottaa tyypin `taxonomy`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"slug":{"description":"Uniikki tunnus sivupohjalle.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Teeman tunniste sivupohjalle.","type":"string","required":false},"type":{"description":"Sivupohjan tyyppi.","type":"string","required":false},"content":{"description":"Sivupohjan sis\u00e4lt\u00f6.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan sis\u00e4lt\u00f6 sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit"]},"block_version":{"description":"Sivupohjan k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkomuodon versio.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Sivupohjan otsikko.","type":["object","string"],"properties":{"raw":{"description":"Sivupohjan otsikko sellaisena kuin se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Sivupohjan HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Sivupohjan kuvaus.","type":"string","required":false},"status":{"description":"Sivupohjan tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"author":{"description":"Sivupohjan tekij\u00e4n tunniste.","type":"integer","required":false},"area":{"description":"Miss\u00e4 sivupohjan osaa on tarkoitettu k\u00e4ytett\u00e4v\u00e4n (yl\u00e4- ja alatunniste, jne.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Sivupohjan ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Yleisten tyylien version yl\u00e4tason ID.","type":"integer","required":false},"id":{"description":"Yksil\u00f6llinen tunniste yleisten tyylien versiolle.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Teeman tunniste","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Teeman tunniste","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Yleisten tyylien m\u00e4\u00e4rityksen ID.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Yleiset tyylit.","type":["object"],"required":false},"settings":{"description":"Yleiset asetukset.","type":["object"],"required":false},"title":{"description":"Yleisten tyylien variaation otsikko.","type":["object","string"],"properties":{"raw":{"description":"Yleisten tyylien variaation otsikko, kuten se on tietokannassa.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kohteen ominaisuuden mukaan.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Ylemm\u00e4n version ID.","type":"integer","required":false},"id":{"description":"Version uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska versiot eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit","embed"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Typografia-asetuksissa k\u00e4ytetyn theme.json-skeeman versio.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family -m\u00e4\u00e4ritys theme.json-muodossa, koodattu merkkijonona.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"theme_json_version":{"description":"Typografia-asetuksissa k\u00e4ytetyn theme.json-skeeman versio.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family -m\u00e4\u00e4ritys theme.json-muodossa, koodattu merkkijonona.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Fontin oman fonttiperheen tunnus (ID).","type":"integer","required":true},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Fontin oman fonttiperheen tunnus (ID).","type":"integer","required":true},"theme_json_version":{"description":"Typografia-asetuksissa k\u00e4ytetyn theme.json-skeeman versio.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"font-face -m\u00e4\u00e4ritys theme.json-muodossa, koodattu merkkijonona.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Fontin oman fonttiperheen tunnus (ID).","type":"integer","required":true},"id":{"description":"Fonttien uniikki tunniste.","type":"integer","required":true},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Fontin oman fonttiperheen tunnus (ID).","type":"integer","required":true},"id":{"description":"Fonttien uniikki tunniste.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"product_brand":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan product_brand.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_brand_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa product_brand.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_cat":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan product_cat.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_cat_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa product_cat.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_tag":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan product_tag.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_tag_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa product_tag.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"brand":{"description":"Limit result set to products assigned a specific brand ID.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"product_brand":{"description":"Artikkeliin liitetyt termit luokittelussa product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Artikkeliin liitetyt termit luokittelussa product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Artikkeliin liitetyt termit luokittelussa product_tag.","type":"array","items":{"type":"integer"},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/product"}]}},"\/wp\/v2\/product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Yliaja otteen oletuspituus.","type":"integer","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"product_brand":{"description":"Artikkeliin liitetyt termit luokittelussa product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Artikkeliin liitetyt termit luokittelussa product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Artikkeliin liitetyt termit luokittelussa product_tag.","type":"array","items":{"type":"integer"},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Artikkelin ote.","type":"object","properties":{"raw":{"description":"Artikkelin ote siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen ote sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Onko ote suojattu salasanalla. ","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"product_brand":{"description":"Artikkeliin liitetyt termit luokittelussa product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Artikkeliin liitetyt termit luokittelussa product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Artikkeliin liitetyt termit luokittelussa product_tag.","type":"array","items":{"type":"integer"},"required":false},"group_of_quantity":{"description":"Require products to be purchased in multiples of this value.","type":"integer","required":false},"min_quantity":{"description":"Minimum required product quantity.","type":"integer","required":false},"max_quantity":{"description":"Maximum allowed product quantity.","type":["integer","string"],"required":false},"exclude_order_quantity_value_rules":{"description":"Exclude product from order quantity and value rules.","type":"string","enum":["yes","no"],"required":false},"exclude_category_quantity_rules":{"description":"Exclude product from category quantity rules.","type":"string","enum":["yes","no"],"required":false},"combine_variations":{"description":"Enable this option to combine the quantities of all purchased variations when checking quantity rules.","type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/support":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"support-category":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan support-category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"support-category_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa support-category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"support-category":{"description":"Artikkeliin liitetyt termit luokittelussa support-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/support"}]}},"\/wp\/v2\/support\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"support-category":{"description":"Artikkeliin liitetyt termit luokittelussa support-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/support\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"support-category":{"description":"Artikkeliin liitetyt termit luokittelussa support-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/support\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/use-case":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4yksen j\u00e4lkeen.","type":"string","format":"date-time","required":false},"before":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Rajoita vastaus julkaisuihin, joita on muokattu ennen annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4yst\u00e4.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Kuinka tulkita hakusy\u00f6tett\u00e4.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi polkutunnus.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Rajaa tulokset artikkeleihin, joilla on yksi tai useampi tila.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","dp-rewrite-republish","any"],"type":"string"},"required":false},"tax_relation":{"description":"Rajoita tuloksia useampien luokittelujen v\u00e4listen suhteiden perusteella.","type":"string","enum":["AND","OR"],"required":false},"case-category":{"description":"Rajoita tulos kohteisiin, joilla on tiettyj\u00e4 termej\u00e4 asetettuna taksonomiaan case-category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false},"operator":{"description":"Annetaanko kohteille kaikki vai jokin m\u00e4\u00e4ritetyist\u00e4 termeist\u00e4.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"case-category_exclude":{"description":"Rajaa tulos sis\u00e4lt\u00e4m\u00e4\u00e4n kaikki kohteet lukuun ottamatta niit\u00e4, joilla on nimetty termi taksonomiassa case-category.","type":["object","array"],"oneOf":[{"title":"Termitunnistelistaus","description":"Sovita termit yhteen listattujen tunnisteiden kanssa.","type":"array","items":{"type":"integer"}},{"title":"Termin tunnisteen taksonomiakysely","description":"Suorita edistynyt termikysely.","type":"object","properties":{"terms":{"description":"Termitunnisteet.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Sis\u00e4ltyv\u00e4tk\u00f6 lapsitermit termeihin, jotka rajoittavat tulosjoukkoa.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"case-category":{"description":"Artikkeliin liitetyt termit luokittelussa case-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/use-case"}]}},"\/wp\/v2\/use-case\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"case-category":{"description":"Artikkeliin liitetyt termit luokittelussa case-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Artikkelin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/use-case\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"date":{"description":"Artikkelin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Artikkelin julkaisup\u00e4iv\u00e4 GMT-ajassa.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Artikkelin alfanumeerinen tunniste, joka on saman artikkelityypin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"status":{"description":"Artikkelin nimetty tila.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft"],"required":false},"password":{"description":"Salasana sis\u00e4ll\u00f6n ja otteen suojaamiseksi. ","type":"string","required":false},"title":{"description":"Artikkelin otsikko.","type":"object","properties":{"raw":{"description":"Artikkelin otsikko siten kuin se esiintyy tietokannassa. ","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-muotoinen otsikko sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Artikkelin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Artikkelin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Artikkelin HTML-sis\u00e4lt\u00f6 sellaisena kuin se n\u00e4ytet\u00e4\u00e4n selaimessa.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Artikkelin k\u00e4ytt\u00e4m\u00e4n sis\u00e4lt\u00f6lohkoformaatin versio.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Onko sis\u00e4lt\u00f6 suojattu salasanalla.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Kohteen artikkelikuvan ID.","type":"integer","required":false},"template":{"description":"Teeman tiedosto joka n\u00e4ytt\u00e4\u00e4 artikkelin.","type":"string","required":false},"case-category":{"description":"Artikkeliin liitetyt termit luokittelussa case-category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/use-case\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Ylemm\u00e4n automaattitallennuksen ID.","type":"integer","required":false},"id":{"description":"Automaattisesti tallennetun version ID.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Alfanumeerinen tunniste sis\u00e4lt\u00f6tyypille.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Alfanumeerinen tunniste tilalle.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Rajaa tuloksiin taksonomioihin, jotka liittyv\u00e4t tiettyyn sis\u00e4lt\u00f6tyyppiin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Alfanumeerinen tunniste taksonomialle.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"parent":{"description":"Rajaa tulokset tiettyyn yl\u00e4tasoon liittymisen mukaan.","type":"integer","required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"locations":{"description":"Sijainnit, jotka on asetettu t\u00e4lle valikolle.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Lis\u00e4t\u00e4\u00e4nk\u00f6 p\u00e4\u00e4tason sivut automaattisesti t\u00e4h\u00e4n valikkoon.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"locations":{"description":"Sijainnit, jotka on asetettu t\u00e4lle valikolle.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Lis\u00e4t\u00e4\u00e4nk\u00f6 p\u00e4\u00e4tason sivut automaattisesti t\u00e4h\u00e4n valikkoon.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product_brand":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"parent":{"description":"Rajaa tulokset tiettyyn yl\u00e4tasoon liittymisen mukaan.","type":"integer","required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/product_brand"}]}},"\/wp\/v2\/product_brand\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product_cat":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"parent":{"description":"Rajaa tulokset tiettyyn yl\u00e4tasoon liittymisen mukaan.","type":"integer","required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/product_cat"}]}},"\/wp\/v2\/product_cat\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/product_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/product_tag"}]}},"\/wp\/v2\/product_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/support-category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"parent":{"description":"Rajaa tulokset tiettyyn yl\u00e4tasoon liittymisen mukaan.","type":"integer","required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/support-category"}]}},"\/wp\/v2\/support-category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/case-category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma termin ominaisuuden mukaan.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Piilotetaanko termit, jotka eiv\u00e4t liity mihink\u00e4\u00e4n artikkeliin?","type":"boolean","default":false,"required":false},"parent":{"description":"Rajaa tulokset tiettyyn yl\u00e4tasoon liittymisen mukaan.","type":"integer","required":false},"post":{"description":"Rajaa tulokset termeihin, jotka liittyv\u00e4t tiettyyn artikkeliin.","type":"integer","default":null,"required":false},"slug":{"description":"Rajaa tulokset termeihin yhdell\u00e4 tai useammalla polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":true},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/case-category"}]}},"\/wp\/v2\/case-category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"description":{"description":"Termin kuvaus HTML-muodossa.","type":"string","required":false},"name":{"description":"HTML-muotoiltu otsikko termille.","type":"string","required":false},"slug":{"description":"Termin alfanumeerinen tunniste joka on saman lajin sis\u00e4ll\u00e4 yksil\u00f6iv\u00e4.","type":"string","required":false},"parent":{"description":"Ylemm\u00e4n tason termin ID.","type":"integer","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"group_of_quantity":{"type":"string","title":"","description":"","default":""}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Yksil\u00f6iv\u00e4 tunniste termille.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon tulee olla true, koska termit eiv\u00e4t tue roskakoria.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"default":"asc","description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Lajittele kokoelma k\u00e4ytt\u00e4j\u00e4n ominaisuuden mukaan.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Rajaa tulokset k\u00e4ytt\u00e4jiin yhdell\u00e4 tai useammalla tietyll\u00e4 polkutunnuksella.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Rajaa tulokset koskemaan v\u00e4hint\u00e4\u00e4n yht\u00e4 annettua roolia. Hyv\u00e4ksyy csv-luettelon tai yksitt\u00e4isen roolin.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Rajaa tulokset koskemaan v\u00e4hint\u00e4\u00e4n yht\u00e4 annettua k\u00e4ytt\u00f6oikeutta. Hyv\u00e4ksyy csv-luettelon tai yksitt\u00e4isen k\u00e4ytt\u00f6oikeuden.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Rajoita tulokset niihin, jotka ovat sivuston kirjoittajia.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Rajoita tulokset niihin, jotka ovat julkaisseet artikkeleita.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","product":"product","support":"support","use-case":"use-case"}},"required":false},"search_columns":{"default":[],"description":"Taulukko sarakkeiden nimist\u00e4, joista etsit\u00e4\u00e4n.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"K\u00e4ytt\u00e4j\u00e4n k\u00e4ytt\u00e4j\u00e4tunnus.","type":"string","required":true},"name":{"description":"K\u00e4ytt\u00e4j\u00e4n n\u00e4ytt\u00f6nimi.","type":"string","required":false},"first_name":{"description":"K\u00e4ytt\u00e4j\u00e4n etunimi.","type":"string","required":false},"last_name":{"description":"K\u00e4ytt\u00e4j\u00e4n sukunimi.","type":"string","required":false},"email":{"description":"K\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":true},"url":{"description":"K\u00e4ytt\u00e4j\u00e4n URL-osoite.","type":"string","format":"uri","required":false},"description":{"description":"K\u00e4ytt\u00e4j\u00e4n kuvaus.","type":"string","required":false},"locale":{"description":"K\u00e4ytt\u00e4j\u00e4n kieli.","type":"string","enum":["","en_US","en_GB","fi"],"required":false},"nickname":{"description":"K\u00e4ytt\u00e4j\u00e4n lempinimi.","type":"string","required":false},"slug":{"description":"K\u00e4ytt\u00e4j\u00e4n alfanumeerinen tunniste.","type":"string","required":false},"roles":{"description":"K\u00e4ytt\u00e4j\u00e4lle asetetut roolit.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"K\u00e4ytt\u00e4j\u00e4n salasana (ei koskaan sis\u00e4lly).","type":"string","required":true},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"P\u00e4iv\u00e4m\u00e4\u00e4t\u00e4 ja aika, jolloin valintoja p\u00e4ivitettiin.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"K\u00e4ytt\u00e4j\u00e4n uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"K\u00e4ytt\u00e4j\u00e4n uniikki tunniste.","type":"integer","required":false},"username":{"description":"K\u00e4ytt\u00e4j\u00e4n k\u00e4ytt\u00e4j\u00e4tunnus.","type":"string","required":false},"name":{"description":"K\u00e4ytt\u00e4j\u00e4n n\u00e4ytt\u00f6nimi.","type":"string","required":false},"first_name":{"description":"K\u00e4ytt\u00e4j\u00e4n etunimi.","type":"string","required":false},"last_name":{"description":"K\u00e4ytt\u00e4j\u00e4n sukunimi.","type":"string","required":false},"email":{"description":"K\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"url":{"description":"K\u00e4ytt\u00e4j\u00e4n URL-osoite.","type":"string","format":"uri","required":false},"description":{"description":"K\u00e4ytt\u00e4j\u00e4n kuvaus.","type":"string","required":false},"locale":{"description":"K\u00e4ytt\u00e4j\u00e4n kieli.","type":"string","enum":["","en_US","en_GB","fi"],"required":false},"nickname":{"description":"K\u00e4ytt\u00e4j\u00e4n lempinimi.","type":"string","required":false},"slug":{"description":"K\u00e4ytt\u00e4j\u00e4n alfanumeerinen tunniste.","type":"string","required":false},"roles":{"description":"K\u00e4ytt\u00e4j\u00e4lle asetetut roolit.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"K\u00e4ytt\u00e4j\u00e4n salasana (ei koskaan sis\u00e4lly).","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"P\u00e4iv\u00e4m\u00e4\u00e4t\u00e4 ja aika, jolloin valintoja p\u00e4ivitettiin.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"K\u00e4ytt\u00e4j\u00e4n uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Arvon on oltava tosi, koska k\u00e4ytt\u00e4j\u00e4t eiv\u00e4t tue roskakori-toimintoa.","required":false},"reassign":{"type":"integer","description":"Merkitse poistetun k\u00e4ytt\u00e4j\u00e4n artikkelit ja linkit t\u00e4lle k\u00e4ytt\u00e4j\u00e4-ID:lle.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"K\u00e4ytt\u00e4j\u00e4n k\u00e4ytt\u00e4j\u00e4tunnus.","type":"string","required":false},"name":{"description":"K\u00e4ytt\u00e4j\u00e4n n\u00e4ytt\u00f6nimi.","type":"string","required":false},"first_name":{"description":"K\u00e4ytt\u00e4j\u00e4n etunimi.","type":"string","required":false},"last_name":{"description":"K\u00e4ytt\u00e4j\u00e4n sukunimi.","type":"string","required":false},"email":{"description":"K\u00e4ytt\u00e4j\u00e4n s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"url":{"description":"K\u00e4ytt\u00e4j\u00e4n URL-osoite.","type":"string","format":"uri","required":false},"description":{"description":"K\u00e4ytt\u00e4j\u00e4n kuvaus.","type":"string","required":false},"locale":{"description":"K\u00e4ytt\u00e4j\u00e4n kieli.","type":"string","enum":["","en_US","en_GB","fi"],"required":false},"nickname":{"description":"K\u00e4ytt\u00e4j\u00e4n lempinimi.","type":"string","required":false},"slug":{"description":"K\u00e4ytt\u00e4j\u00e4n alfanumeerinen tunniste.","type":"string","required":false},"roles":{"description":"K\u00e4ytt\u00e4j\u00e4lle asetetut roolit.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"K\u00e4ytt\u00e4j\u00e4n salasana (ei koskaan sis\u00e4lly).","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"P\u00e4iv\u00e4m\u00e4\u00e4t\u00e4 ja aika, jolloin valintoja p\u00e4ivitettiin.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Arvon on oltava tosi, koska k\u00e4ytt\u00e4j\u00e4t eiv\u00e4t tue roskakori-toimintoa.","required":false},"reassign":{"type":"integer","description":"Merkitse poistetun k\u00e4ytt\u00e4j\u00e4n artikkelit ja linkit t\u00e4lle k\u00e4ytt\u00e4j\u00e4-ID:lle.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Sovelluksen tarjoama yksil\u00f6llinen UUID sen tunnistamiseksi. UUID v5:n k\u00e4ytt\u00f6 on suositeltavaa, joko URL- tai DNS-nimiavaruuden kanssa.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Sovellussalasanan nimi.","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Sovelluksen tarjoama yksil\u00f6llinen UUID sen tunnistamiseksi. UUID v5:n k\u00e4ytt\u00f6 on suositeltavaa, joko URL- tai DNS-nimiavaruuden kanssa.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Sovellussalasanan nimi.","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"after":{"description":"Rajoita tulokset artikkeleihin, jotka on julkaistu annetun ISO8601-yhteensopivan p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n j\u00e4lkeen.","type":"string","format":"date-time","required":false},"author":{"description":"Rajaa tulokset kommentteihin, jotka on liitetty tiettyihin k\u00e4ytt\u00e4j\u00e4-ID:isiin. Vaatii tunnistautumisen.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Varmistaa ettei kommentteja ole liitetty tiettyihin k\u00e4ytt\u00e4j\u00e4-ID:isiin. Vaatii tunnistautumisen.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Rajaa tulokset tietyll\u00e4 kirjoittajan s\u00e4hk\u00f6postiosoitteella. Vaatii tunnistautumisen.","format":"email","type":"string","required":false},"before":{"description":"Rajoita tulokset kommentteihin, jotka on julkaistu annettua ISO8601-yhteensopivaa p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4\u00e4 ennen.","type":"string","format":"date-time","required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"J\u00e4rjest\u00e4 kokoelma kommentin ominaisuuden mukaan.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Rajaa tulokset kommentteihin, joilla on tiettyjen vanhempien ID.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Varmistaa ettei tuloksilla ole tietty\u00e4 vanhemman ID:t\u00e4.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Rajaa tulokset kommentteihin, joille on asetettu tietty artikkeli-ID.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Rajaa tulokset kommentteihin, joille on asetettu tietty tila. Vaatii tunnistautumisen.","type":"string","required":false},"type":{"default":"comment","description":"Rajaa tulokset kommentteihin, joille on asetettu tietty tyyppi. Vaatii tunnistautumisen.","type":"string","required":false},"password":{"description":"Artikkelin salasana, jos se on salasanasuojattu. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"K\u00e4ytt\u00e4j\u00e4n ID, jos kirjoittaja on tiedossa.","type":"integer","required":false},"author_email":{"description":"Kommentin kirjoittajan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"author_ip":{"description":"Kommentin kirjoittajan IP-osoite.","type":"string","format":"ip","required":false},"author_name":{"description":"Kommentin kirjoittajan n\u00e4ytt\u00f6nimi.","type":"string","required":false},"author_url":{"description":"Kommentin kirjoittajan URL.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Kommentin kirjoittajan user agent -tieto.","type":"string","required":false},"content":{"description":"Kommentin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Kommentin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Kommentin HTML-sis\u00e4lt\u00f6, joka on muunnettu n\u00e4ytett\u00e4v\u00e4ksi.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Kommentin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Kommentin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 GMT-ajassa.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Ylemm\u00e4n kommentin ID.","type":"integer","required":false},"post":{"default":0,"description":"Liittyv\u00e4n artikkelin ID.","type":"integer","required":false},"status":{"description":"Kommentin tila. ","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Huomion ratkaisun tila","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Kommentin uniikki tunniste.","type":"integer","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Kommentin artikkelin salasana (jos artikkeli on salasanasuojattu).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Kommentin uniikki tunniste.","type":"integer","required":false},"author":{"description":"K\u00e4ytt\u00e4j\u00e4n ID, jos kirjoittaja on tiedossa.","type":"integer","required":false},"author_email":{"description":"Kommentin kirjoittajan s\u00e4hk\u00f6postiosoite.","type":"string","format":"email","required":false},"author_ip":{"description":"Kommentin kirjoittajan IP-osoite.","type":"string","format":"ip","required":false},"author_name":{"description":"Kommentin kirjoittajan n\u00e4ytt\u00f6nimi.","type":"string","required":false},"author_url":{"description":"Kommentin kirjoittajan URL.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Kommentin kirjoittajan user agent -tieto.","type":"string","required":false},"content":{"description":"Kommentin sis\u00e4lt\u00f6.","type":"object","properties":{"raw":{"description":"Kommentin sis\u00e4lt\u00f6 siin\u00e4 muodossa kuin se on tietokannassa.","type":"string","context":["edit"]},"rendered":{"description":"Kommentin HTML-sis\u00e4lt\u00f6, joka on muunnettu n\u00e4ytett\u00e4v\u00e4ksi.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Kommentin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 sivuston aikavy\u00f6hykkeen ajassa.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Kommentin julkaisup\u00e4iv\u00e4m\u00e4\u00e4r\u00e4 GMT-ajassa.","type":"string","format":"date-time","required":false},"parent":{"description":"Ylemm\u00e4n kommentin ID.","type":"integer","required":false},"post":{"description":"Liittyv\u00e4n artikkelin ID.","type":"integer","required":false},"status":{"description":"Kommentin tila. ","type":"string","required":false},"meta":{"description":"Metakent\u00e4t.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Huomion ratkaisun tila","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Kommentin uniikki tunniste.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ohitetaanko roskakori ja pakotetaan poistaminen.","required":false},"password":{"description":"Kommentin artikkelin salasana (jos artikkeli on salasanasuojattu).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"type":{"default":"post","description":"Rajaa tuloksia yhden oliotyypin kohteisiin.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Rajaa tuloksia yhteen tai useampaan olion alatyyppiin.","type":"array","items":{"enum":["post","page","product","support","use-case","category","post_tag","product_brand","product_cat","product_tag","support-category","case-category","any"],"type":"string"},"required":false},"exclude":{"description":"Varmista, etteiv\u00e4t tulokset sis\u00e4ll\u00e4 tiettyj\u00e4 ID:it\u00e4.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Rajaa tulokset tiettyihin ID:ihin.","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Lohkolle rekister\u00f6ity yksil\u00f6llinen nimi","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Lohkon ominaisuudet.","type":"object","default":[],"required":false},"post_id":{"description":"Artikkelin kontekstin ID.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Lohkon nimiavaruus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Lohkon nimiavaruus.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Lohkon nimi.","type":"string","required":false},"namespace":{"description":"Lohkon nimiavaruus.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Otsikko","description":"Sivuston otsikko.","type":"string","required":false},"description":{"title":"Kuvaus","description":"Sivuston kuvaus.","type":"string","required":false},"url":{"title":"","description":"Sivuston URL.","type":"string","format":"uri","required":false},"email":{"title":"","description":"T\u00e4t\u00e4 osoitetta k\u00e4ytet\u00e4\u00e4n yll\u00e4pidon teht\u00e4viin, kuten uusien k\u00e4ytt\u00e4jien rekister\u00f6itymisilmoituksiin.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Kaupunki samalla aikavy\u00f6hykkeell\u00e4 kuin sin\u00e4.","type":"string","required":false},"date_format":{"title":"","description":"Muoto kaikille p\u00e4iv\u00e4m\u00e4\u00e4r\u00e4n merkkijonoille.","type":"string","required":false},"time_format":{"title":"","description":"Muoto kaikille kellonajan merkkijonoille.","type":"string","required":false},"start_of_week":{"title":"","description":"Viikonp\u00e4iv\u00e4n numero josta viikko alkaa.","type":"integer","required":false},"language":{"title":"","description":"WordPressin kieli- ja maakoodi.","type":"string","required":false},"use_smilies":{"title":"","description":"Muunna hymi\u00f6t kuviksi.","type":"boolean","required":false},"default_category":{"title":"","description":"Oletuskategoria artikkeleille.","type":"integer","required":false},"default_post_format":{"title":"","description":"Artikkelisivujen oletusmuoto.","type":"string","required":false},"posts_per_page":{"title":"Enimm\u00e4ism\u00e4\u00e4r\u00e4 artikkeleita sivulla","description":"N\u00e4yt\u00e4 enint\u00e4\u00e4n","type":"integer","required":false},"show_on_front":{"title":"N\u00e4yt\u00e4 etusivulla","description":"Mit\u00e4 n\u00e4ytet\u00e4\u00e4n etusivulla","type":"string","required":false},"page_on_front":{"title":"Etusivu","description":"Tunniste sivusta, joka n\u00e4ytet\u00e4\u00e4n etusivulla","type":"integer","required":false},"page_for_posts":{"title":"","description":"Tunniste sivusta, joka n\u00e4ytt\u00e4\u00e4 uusimmat artikkelit","type":"integer","required":false},"default_ping_status":{"title":"","description":"Salli linkki-ilmoitukset muista blogeista (pingback ja trackback) uusiin artikkeleihin.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Salli kommentointi uusiin artikkeleihin","description":"Salli uusien artikkelien kommentointi.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Sivuston logo.","type":"integer","required":false},"site_icon":{"title":"Kuvake","description":"Sivuston kuvake.","type":"integer","required":false},"pickup_location_settings":{"title":"","description":"WooCommerce Local Pickup Method Settings","type":"object","properties":{"enabled":{"description":"Jos t\u00e4m\u00e4 on k\u00e4yt\u00f6ss\u00e4, t\u00e4m\u00e4 tapa n\u00e4kyy lohkopohjaisessa kassassa.","type":"string","enum":["yes","no"]},"title":{"description":"Kirjoita t\u00e4h\u00e4n tieto josta k\u00e4ytt\u00e4j\u00e4 tunnistaa maksutavan.","type":"string"},"tax_status":{"description":"Jos kustannus on m\u00e4\u00e4ritelty, t\u00e4m\u00e4 ohjaa sit\u00e4, sovelletaanko kustannuksiin veroja vai ei.","type":"string","enum":["taxable","none"]},"cost":{"description":"Optional cost to charge for local pickup.","type":"string"}},"additionalProperties":false,"required":false},"pickup_locations":{"title":"","description":"WooCommerce Local Pickup Locations","type":"array","items":{"type":"object","properties":{"name":{"type":"string"},"address":{"type":"object","properties":{"address_1":{"type":"string"},"city":{"type":"string"},"state":{"type":"string"},"postcode":{"type":"string"},"country":{"type":"string"}},"additionalProperties":false},"details":{"type":"string"},"enabled":{"type":"boolean"}},"additionalProperties":false},"required":false},"woocommerce_default_catalog_orderby":{"title":"Tuotteiden lajittelu, oletus","description":"Kuinka tuotteet oletuksena lajitellaan tuoteluettelossa?","type":"string","enum":["menu_order","popularity","rating","date","price","price-desc"],"required":false},"woocommerce_checkout_phone_field":{"title":"Puhelinnumero","description":"Controls the display of the phone field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_company_field":{"title":"Yritys","description":"Controls the display of the company field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false},"woocommerce_checkout_address_2_field":{"title":"Address Line 2","description":"Controls the display of the apartment (address_2) field in checkout.","type":"string","enum":["optional","required","hidden"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Rajaa tuloksia teeman tilan perusteella.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Teeman tyylitiedosto. M\u00e4\u00e4rittelee teeman yksil\u00f6llisesti.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","required":false},"status":{"description":"Rajoita tulokset m\u00e4\u00e4r\u00e4tyn tilan omaaviin lis\u00e4osiin.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org-lis\u00e4osahakemiston polkutunnus.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Lis\u00e4osan tila.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Lis\u00e4osan tila.","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Rekister\u00f6idyn sivupalkin ID","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Sis\u00e4kk\u00e4iset vimpaimet.","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Vimpaintyypin ID.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Vimpaintyypin ID.","type":"string","required":true},"instance":{"description":"Nykyisen instanssin vimpainasetukset.","type":"object","required":false},"form_data":{"description":"Serialisoitu vimpainen lomakedata koodattavaksi instanssin asetuksiin.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Vimpaintyypin ID.","type":"string","required":true},"instance":{"description":"Nykyisen instanssin vimpainasetukset.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Sivupalkki, jonka vimpaimet n\u00e4ytet\u00e4\u00e4n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Vimpaimen uniikki tunniste.","type":"string","required":false},"id_base":{"description":"Vimpaimen tyyppi. Vastaa ID:t\u00e4 \"widget-types\"-p\u00e4\u00e4tepisteess\u00e4.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Sivupalkki, johon vimpain kuuluu.","type":"string","required":true},"instance":{"description":"Vimpaimen instanssiasetukset, jos tuettu.","type":"object","properties":{"encoded":{"description":"Instanssiasetusten Base64-koodattu vastine.","type":"string","context":["edit"]},"hash":{"description":"Instanssiasetusten kryptograafinen tiiviste.","type":"string","context":["edit"]},"raw":{"description":"Ei-koodatut instanssiasetukset, jos tuettu.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-enkoodattu lomakedata vimpaimen hallintalomakkeesta. K\u00e4ytet\u00e4\u00e4n sellaisen vimpaimen p\u00e4ivitt\u00e4miseen, joka ei tue instansseja. Vain kirjoitettavissa.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Vimpaimen uniikki tunniste.","type":"string","required":false},"id_base":{"description":"Vimpaimen tyyppi. Vastaa ID:t\u00e4 \"widget-types\"-p\u00e4\u00e4tepisteess\u00e4.","type":"string","required":false},"sidebar":{"description":"Sivupalkki, johon vimpain kuuluu.","type":"string","required":false},"instance":{"description":"Vimpaimen instanssiasetukset, jos tuettu.","type":"object","properties":{"encoded":{"description":"Instanssiasetusten Base64-koodattu vastine.","type":"string","context":["edit"]},"hash":{"description":"Instanssiasetusten kryptograafinen tiiviste.","type":"string","context":["edit"]},"raw":{"description":"Ei-koodatut instanssiasetukset, jos tuettu.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-enkoodattu lomakedata vimpaimen hallintalomakkeesta. K\u00e4ytet\u00e4\u00e4n sellaisen vimpaimen p\u00e4ivitt\u00e4miseen, joka ei tue instansseja. Vain kirjoitettavissa.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Poistetaanko vimpain vai siirret\u00e4\u00e4nk\u00f6 se poissa k\u00e4yt\u00f6st\u00e4 oleviin vimpaimiin.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Rajoita hakusanalla l\u00f6ytyvien lohkojen m\u00e4\u00e4r\u00e4\u00e4.","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t merkkijonoon. ","type":"string","minLength":1,"required":false},"category":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t kategorian ID:hen. ","type":"integer","minimum":1,"required":false},"keyword":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t avainsanan ID:hen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Rajaa tulokset niihin, jotka t\u00e4sm\u00e4\u00e4v\u00e4t lohkomalliin (polkutunnus). ","type":"array","required":false},"offset":{"description":"Ohita m\u00e4\u00e4ritelty m\u00e4\u00e4r\u00e4 kohteita alusta.","type":"integer","required":false},"order":{"description":"J\u00e4rjest\u00e4\u00e4 tulokset nousevaan tai laskevaan j\u00e4rjestykseen.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Lajittele kokoelma artikkelin ominaisuuden mukaan.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Verkko-osoite (URL) k\u00e4sitelt\u00e4v\u00e4ksi.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Alfanumeerinen tunniste valikon sijainnille.","type":"string","required":false},"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Kokoelman nykyinen sivu.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Haun palauttamien tulosten enimm\u00e4ism\u00e4\u00e4r\u00e4.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Pyynn\u00f6n konteksti m\u00e4\u00e4r\u00e4\u00e4 mit\u00e4 kentti\u00e4 vastauksessa on mukana.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fi"],"required":false}}}]}},"site_logo":0,"site_icon":9,"site_icon_url":"https:\/\/cloud.ruuvi.com\/i\/u\/2020\/10\/favicon.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/cloud.ruuvi.com\/fi\/wp-json\/wp\/v2\/media\/9"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
